FS above player bought new around 18months ago in silver, with remote, and I reckon I have the box and manual, will advise. Specifications for the MDSJE480 Minidisc Recorder Sampling Frequencies 44.1 kHz Sample Rate Converter 48/32kHz to 44.1kHz A/D Converter 1-Bit Delta Sigma (24-Bit) Error Correction CIRC Data Compression System ATRAC 1 Type -R- ATRAC 3 Frequency Response 5-20,000 Hz ±0.3dB Signal-To-Noise Ratio >96dB Wow & Flutter Below Measurable Limit Power 220-230V 50/60Hz @ 15W Dimensions Width: 430mm Height: 95mm Depth: 285mm Weight 3Kg Pics can be seen in my pics list, will get actual pics later, good condition, couple of light scratches, but perfect mechanichally, this has not been used too much, as used mainly to record aerobic routines, which were played back on anohter player. PM if interested, can demo, nr Glasgow. Looking for £55 delivered UK or £50 pick up, firm price, it's easy worth this. Will also include 6 sealed unused blank 74m MD's
