We are now stocking the higher-end Soundmagic headphone/earphones (PL50 and P30) - both models are absoultely astonishing value for money and offer incredible sound for under £80, both models put far-more expensive well-known brands to shame! [COLOR="Blue"][B][SIZE="2"]As with all of our products, these are sourced from official UK channels and are supplied with full UK warranty, they are not "grey" imports or counterfeit models which may be offered at discounted prices by less reputable retailers.[/SIZE][/B][/COLOR] [URL]http://www.ipodaudio.co.uk/earphones.html[/URL] 01403 789 226 [email]audiologica@btconnect.com[/email] [B]Soundmagic PL50[/B] Combining an ergonomic, professional in-ear design with little weight makes the PL50 extremely comfortable to wear. Comfortable optional over-ear guides make sure the PL50 sit securely in your ear in any activity. Invigorating and clear sound of the PL50 is also assured as the over-the-ear guides help reduce microphonic noise travelling up the cable. External noise is kept to a minimum due to the sound isolating in-ear design of the PL50 allowing for undiluted listening pleasure from the high to low frequencies of the sound spectrum. When not in use, the PL50 can be stored in the supplied storage case. Speaker: 6.4mm balanced armature transducer Impedance: 55.5ohm +/-15% (@ 1kHz) Sensitivity: 109 +/-2dB Frequency Response: 15Hz to 22kHz Rated Power: 2mW Max Power: 10mW Connector: 3.5mm gold plated jack Cable Length: 1.2m symmetrical [B]Soundmagic P30[/B] P30 are portable headphones that come with a sturdy metal band within the headband and Polycarbonate plastic covering on the earpieces. It uses leather for the earpads and headband so comfort and noise isolation are ticked off the list. The sound signature of the SoundMAGIC P30 is well balanced and accurate with an excellent soundstage and powerful bass. Excellent soundstage, well balanced, powerful bass and accurate sound will take high fidelity to you ears. The P30 also can be folded and put into the supplied travel pouch. The ear cups are covered by high quality metal covers that protect the headphones. SoundMAGIC P30 Features ***Powerful bass and accurate sound ***High quality PU leather ear pads & headband ***Extreme comfortable with excellent noise isolation ***Portable folding design, easy for carrying Technical Specifications ***Driver: Dynamics 40mm Neodymium Driver ***Frequency range: 20Hz - 22 kHz ***DC Resistance: 32 Ω ***Sensitivity: 108dB at 1KHz/mW ***Maximum input power: 100mW ***Cable length: 1.2 m ***Connection: Gold-plated straight stereo 3.5mm ***Weight: 85 g Package Includes ***SoundMAGIC P30 Foldable Closed Back Headphones in Black ***Travel pouch
