As some of you may know I recently replaced my MF amps (X/A2 Int for treble and X-A200 for bass) with a Rogue Stereo 90 valve power amp (for volume control I use a passive attenuator at the moment). Now, I'm happy with some of the improvements that the Rogue has brought but the soundstage has shifted to the left. I played a test disc where a drum note moves from left to right in 7 steps and this confirmed my suspicions. With the MF amps the notes moved from left to right in regular steps. With the Rogue the first 3 notes seem to come from the left speaker then they seem to move to the right but never quite seem to reach the right speaker (if you see what I mean). I have toed out the right speaker and toed in the left for some improvement and also changed the input tubes around (in case the left was providing greater gain) but it's still nowhere as good as it was with the MFs. One other thing that has changed is that my TV packed up, so it's now in the skip, instead of being in the middle of the speakers, which may have an affect. So, any suggestions? it's certainly room related but why should it affect the Rogue more than the MFs? what can I do about it?
