Hi, only my 2nd post, but looking for some opinions. I've bought and sold bits of kit in the past just cos I like a change as well as getting upgrade fever. The remnants of my first system are Dynaudio Audience 52s and Chord Odyssey speaker cable. Electronics wise I'm currently playing with a Meridian 507 and Tag PA10 pre and 60P pwr with an Atlas Voyager between. The sound I get is ok, but just ok. I feel like the the amp and or speakers cant keep up with the music. It struggles to dissect complex tunes like REM's Animal - which souds awful, frankly. I find myself turning the volume up, which I know is a sign of problems somewhere else in system. Only fast punchy songs sound good, like Goldfrapp's Train song. But I imagine that sounds good on any system. Given that the amps are the newest, I dont want to change them. Obviously the sound I want is the hifi nirvana of my system being able to play all music really well! But on a more personal level, i'd like something that isn't imediately obvious, but more draws you into the music over time and becomes a really engaging listen. As an example, I dont want Cyrus-ie stuff. Had it in the past, but found it tiring to listen to all afternoon. Too aggressive for my ears. But ultimately I want my foot to tap to this system. It sounds so slow, lifeless and doing "hifi" by the numbers. The power amp is only 60wpc and the speakers are a bit difficult to drive; 86db/4ohms. So I suspect getting more sensitive speakers might let the amp be more incontrol instead of being over-run. That a fair comment? I'd say the system can sound a little bright at times at the moment, bass is ok. My listening room is small - still in my beedroom, with laminate flooring. One consideration I have is using my hifi speakers as part of an AV set up when I move out next year. All these unfamiliar brands you guys talk about ive never heard of, can afford, or dont even know if they do cinema speakers. So farely mainstream speakers are what I'm after, only so as I can get hold of a new centre and rear channel speaks which will match tonally. Not sure of a budget, £500 maybe, so buying second hand is probably very likely. I like the B&W CDM 1NTs but no idea if they will go. Tag helpesk suggested the Quad L series. Imagine that. Meridian said they were too unfamiliar with Tag to comment. What do you geniuses propose? Cheers in advance - Phil
