speaker binding post/jumpers question
Discussion in 'Hi-Fi and General Audio' started by Ya-Boo, Sep 21, 2003.
  1. Ya-Boo
    Ya-Boo
    497
    Just a quick one
    I,m changing from bi-wire too single run's, the cable I,ve got
    has network box's and are like, hose pipe thick.
    i understand the Ideal would be some identical cable but being American I have tried to locate some but
    have had no luck, still awaitng absolute sounds return call
    whats the next best option? and is there a benchmark length for jumpers?
    About a 1 year ago I,d have said that the whole cables issue
    was total bollocks...... not anymore..........
    these latest cables gave me one of the biggest steps forward in my systems quaility and enjoyment
  2. Ya-Boo
    Warren M
    67
    London
    Do your cables have any lead-out wire?
    i.e. some smaller cables that go from your "network box's" to the speaker terminals.
    If you do then see if you can get some more of that from the cable manufacturer to use as jumpers.
    If you are up to it, you could try opening up your speakers and connecting the HF & LF from your crossover to one set of terminals per speaker.
    ***WARNING***
    I would not attempt this unless you are confident about what you are doing and are prepared to invalidate any remaining warranty on your speakers.
    Warren M, Sep 22, 2003
  3. Ya-Boo
    zanash
    3,826
    Notts.
    Not heard from you for a while how are the cables coming along ?
    zanash, Sep 22, 2003
  4. Ya-Boo
    zanash
    3,826
    Notts.
    I can provide a mean set of twisted silver wire to replace the nasty brass jumpers often used.
    Just made my self a set 3 x 50mm 1mm 4n Ag wire per connection.
  5. Ya-Boo
    voodoo OdD
    983
    Utopolis
    So what'ya got then Ya-Boo ?
    MIT ?
    Transparent ?
    voodoo, Sep 22, 2003
  6. Ya-Boo
    6,766
    bucks
    Hey Pete - heres a nifty one for you.. have you tried this?
    I twisted some silver together for my jumpers too... and painted them with some clear varnish - which stopped the silver from corroding and uses air as a dialectic. Good idea eh? :)
    Chris
    bottleneck, Sep 22, 2003
  7. Ya-Boo
    Warren M
    67
    London
    If you painted the silver wire with varnish isn't the varnish then the dialectic?
  8. Ya-Boo
    zanash
    3,826
    Notts.
    I think you told me l when I came down ...... I did consider it but a quick scuttle with the duraglit
    sorts it .........silver tarnish is a conductor so no problems in that department.
    And yes the eurathane varnish [?] willnow be the dielectric but its very thin !
  9. Ya-Boo
    Ya-Boo
    497
    Voodoo
    I,m using Transparent....... rather by luck than judgement
    was offered some too home dem, I had never even considered it as an option because of the horrifiying cost of the stuff
    The improvment was so vast i just had to buy some
    moved my rack too make the runs as short as poss too reduce cost
    Hi Zanash
    sorry about the lack of contact of late,
    have now got some matching transparent I/C's to use with speaker cable......
    In my current setup this sounds best
    L'argent,though very good , just has that slightl brightness at the top end that just does'nt suit my system for extended Listening
    kev
    Ya-Boo, Sep 22, 2003
  10. Ya-Boo
    6,026
    Beyond the 4th Dimension
    I have to concede on this, today My new speaker cable arrived , single wire with matching jumpers, tried just the jumpers on the Hollogram II, ho dear what have I been missing :eek:
    Still you live and learn :) WM
    wadia-miester, Sep 22, 2003
  11. Ya-Boo
    Ya-Boo
    497
    Tone how would you describe hollogram 11...??
    would you like to give my transparent a go?
  12. Ya-Boo
    6,026
  13. Ya-Boo
    dave
    Sep 25, 2003
    5
    Oz
    Hi Ya-Boo,
    try an "F" connection
    Has anyone tried a bypass of the terminals and directly soldered speaker cables?
    Dave :confused:
    dave, Sep 26, 2003
