Speaker cable lengths.
Discussion in 'Hi-Fi and General Audio' started by Snoo, Feb 5, 2011.
  1. Snoo
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    Zanash, if you know better than science please do share....
    penance, Feb 7, 2011
    #21
  2. Snoo
    zanash
    3,826
    Notts.
    so you use disimilar length speaker cable in your system ...yes ..no ?
    here's another question for you to ponder ...
    if you had two pairs of interconnect cable ..one pair of equal lenght and one of dissimilar lengths ...which are you going to use to connect your £2.5K cdp to your £3k pre amp ?
    its not my fault physics is the way it is .....if you change the electrical characteristics of one cable ...ie its length as compared to its stereo twin .... it will have an effect of the transmittion of the music signal .....
    whether you have or your system has the resolving ability to hear it or not does not mean the effect is not there.
    If you have or condone a sloppy regime in hifi setup ..... ie if you introduce enough cables of different lengths or different types or different electrical characteristics you will eventually discover that your not allowing your hifi to perform at its best .....
    I do feel for those of you who can see/hear this ....as its seem if you actually believe this doctrine " it doesn't matter what you used any old bit of wire of any length will do " its very clear your not allowing the very expensive hifi to give of there very best ..
    thats my final word on the topic ......if you don't like tough !
    or do you doubt that too ?
    zanash, Feb 7, 2011
    #22
  3. Snoo
    nando nando
    Jun 1, 2006
    4,017
    london
    quote
    god has no hi-ifi only fidelity, as far as moving my ears i don't have to, my tannoys do that perfectly no matter where i am in the house , no need for a sweet spot don't need it,
    nando, Feb 7, 2011
    #23
  4. Snoo
    Jun 30, 2003
    6,004
    You mean beyond your understanding.
    Please show your calculations to quantify this, I doubt you can as it is meaningless dribble.
    That old chesnut!
    It is not about whether there is a measurable change but about whether that change is discernable, which it wont be.
    Straight from the salemans mouth, there you have it people.
    #24
  5. Snoo
    nando nando
    Jun 1, 2006
    4,017
    london
    well put penance, to each it's own preference, and advice is out of the window, so when people want advice on their systems, do not ask here ,send them to the nearest dealer they will gladly tell them to go to maplin, further more everyone has a vision of what they experienced through out "if any here" worked in retail from the wonderful 70's and messed about with nothing more than bell wire and simple interconects, no gold plated crap, then as time went on we , well almost all of us found out the good and bad cables had a substantial effect on your hi-fi.
    nando, Feb 7, 2011
    #25
  6. Snoo
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    You could just as easily argue that longer cables are more susceptible to interference and coiled up cables may introduce inductance.
    I'd say, save money and use the shortest length you can of a reasonably thick cable.
    Dev, Feb 7, 2011
    #26
  7. Snoo
    Labarum
    Oct 18, 2008
    492
    mmm
    Interference? A that low impedance and relatively high voltage. I doubt it.
    Inductance? Doesn't the coiled twin cable form two opposing coils and in theory a non-inductive winding?
    Labarum, Feb 7, 2011
    #27
  8. Snoo
    nando nando
    Jun 1, 2006
    4,017
    london
    resistors in conductivity of electric current flow are coils,
    nando, Feb 7, 2011
    #28
  9. Snoo
    Labarum
    Oct 18, 2008
    492
    #29
  10. Snoo
    felix part-time Horta
    Dec 13, 2003
    757
    dead
    Yes, and not just in theory - I've tried measuring it before to call BS on the 'dont coil it myth that permeates...
    I took 4.0metres of NACA5, one of the more inductive cables on the market, because of the wide spacing between the conductors. Laid out straight, shorted one end...: 3.7uH. Coiled into the tightest flat coil I could arrange (total 8inch outside diameter)..: 4.1uH. So the cancellation isn't perfect... but 0.4uH into 8ohms makes a difference of 0.02dB at 20Khz. Very, very insignificant IMO...
    Mescalito is spot-on - pair-matching in most speakers is probably only 2dB or so; as is channel balance in most good-quality attenuators (many aren't even that good). Either of these is 100x worse in terms of mismatch.
    Moral - coil it up, chop it off, or just dont buy the excess cable in the first place.
    felix, Feb 7, 2011
    #30
  11. Snoo
    nando nando
    Jun 1, 2006
    4,017
    london
    oh well, in the end is practice and not theory i guess we are too busy looking at facts on paper and technicals issues that no longer we use our integrity of hearing the difference, maybe we can't and then maybe we do, sorry if i don't make my self clear, but i beg to differ on some of some views, thanks but.......
    nando, Feb 7, 2011
    #31
  12. Snoo
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Sorry Brian. I should've read my post before submitting. I was merely trying (badly:)) to say that if you can argue that the length of cable affects impedance significantly you can just as easily argue that coiling up the cable can affect inductance. Of course I've never seen anyone wind it up so tightly and as you say we'd have 2 opposing coils anyway.
    Neither argument holds water really, but when has that stopped anyone:D. I saw a cable vendor "demonstrating" the effects of interference at a show a few years ago.
    Dev, Feb 7, 2011
    #32
  13. Snoo
    Snoo
    Sep 8, 2003
    240
    Bristol
    Wow, 3 pages!!!
    I spent a good few years polishing fuses, placing tile spacers under gear and making my own cables. Whilst I can't say I ever heard a difference, I did enjoy it. I've come to the point of being a bit less precious about my hifi. New house and twin babies taking my attention. Chopped the left cable purely for room aesthetics. Sounds fine. Thanks for the opinions folks. As you were. ;-)
    Snoo, Feb 7, 2011
    #33
  14. Snoo
    RobHolt Moderator
    Oct 24, 2004
    Amen!
    RobHolt, Feb 7, 2011
    #34
  15. Snoo
    Labarum
    Oct 18, 2008
    492
    Alleluia! Amen!
    Labarum, Feb 8, 2011
    #35
  16. Snoo
    Mescalito
    Apr 21, 2009
    226
    Scottish Highlands
    You make yourself perfectly clear, Nando. You want to believe that audiophoolery makes a difference, so to you, it does.
    Chris
    Mescalito, Feb 8, 2011
    #36
  17. Snoo
    Snoo
    Sep 8, 2003
    240
    Bristol
    I've been getting into a bit of music production in previous years. There is a very highly regarded mastering engineer named Bob Katz and in one of his books there is a statement:
    "Wearing a hat with a brim will put at notch in your hearing at 2KHz".
    Since reading that I've stopped buying expensive cables and started wearing better hats.
    Snoo, Feb 8, 2011
    #37
  18. Snoo
    nando nando
    Jun 1, 2006
    4,017
    london
    i do not believe that cables should cost the price that some are selling for on the contrary, you can get cables at a fraction of the price witch sound super, me i always use LAT, that's my preference, not every one wears the same hat.
    nando, Feb 8, 2011
    #38
  19. Snoo
    stebbo
    Dec 5, 2003
    83
    A quick back of a fag packet calculation shows the difference in cable length to make an audible difference would need be in the region of 13metres. Even then a change to speaker positioning would negate that.
    However there is one reason to keep speaker cable lengths the same. If at some point you wish to sell them on, it is easy to sell a pair the same length than different lengths.
    stebbo, Feb 9, 2011
    #39
  20. Snoo
    Mescalito
    Apr 21, 2009
    226
    Scottish Highlands
    In the situation where there are speaker leads of equal length, the effect of listening to a system with 1 cable is 0.5m and the other is 10m can be duplicated by moving your head by 22 microns (about a thousandth of an inch).
    So, you can see, the imaging and phase coherence is going to be totally f*cked up by assymetric cabling!
    Chris
    Mescalito, Feb 9, 2011
    #40
