Speaker cable life expectancy?
Discussion in 'Hi-Fi and General Audio' started by cristphoto, May 17, 2020.
  1. cristphoto
    cristphoto
    Apr 14, 2020
    6
    Is there a guideline for how long speaker cables will last? I was adding a component recently and got a close-up look at my speaker cables that are about 20-25 years old. They're 12 gauge with a clear jacket so I could see the strands and they appeared to have lost their bright copper color and appeared a dull brown shade. There wasn't any green corrosion color but I'm curious if there is an age limit. Thanks.
  2. cristphoto
    wallace Only slightly barmy
    Sep 10, 2010
    9
    Bridgwater UK.
    No guidelines,your cables will out live you i imagine,But if you have some spare cash why not buy some new ones.I,for one would be very interested to know if you can hear a difference.
    wallace, Jul 9, 2020
  3. cristphoto
    JohnnyL
    Feb 11, 2022
    6
    I can relate to what you are talking about. I have some 30 year old monster that looks back in spots now. Seems brittle now after I stripped of the jacket. I don't have a meter but would be very curious to how it would test. My feeling is probably not great
    JohnnyL, Feb 11, 2022
  4. cristphoto
    JohnnyL
    Feb 11, 2022
    6
    I did actually buy some pure copper 14 gauge and cut 2- 9 foot pieces. I was using 10 gauge Monster that was rotten. If I striped off the jacket strands would just break off. So in short yes I could hear a difference and for the better.
    JohnnyL, Apr 13, 2022
  5. cristphoto
    lawrence001
    Jul 23, 2010
    49
    13
    No need to replace it, it's just the exposed ends that have oxidised. Cut off half an inch at each end and strip the coating back and you've got a fresh pair of cables.
    lawrence001, May 5, 2022
    Sergeauckland likes this.
  6. cristphoto
    JohnnyL
    Feb 11, 2022
    6
    Not true. Mine is just falling apart and not just at the ends.
    JohnnyL, Aug 2, 2022
  7. cristphoto
    Sergeauckland
    May 31, 2012
    411
    84
    Suffolk
    The insulation of 'speaker cables, or indeed any cables, can degrade with time, the effect of atmospheric oxygen and ultraviolet light, so they won't last 'forever' but will for a very long time, Unless the copper has gone brittle, any corrosion will be just on the surface, so won't affect audio to any great extent, but sticky cables aren't nice so should be replaced. I've used QED 79 strand or 15 amp two core mains cable perfectly happily, so you definitely DON'T need anything fancier.
    S
    Sergeauckland, Aug 2, 2022
    JohnnyL likes this.
  8. cristphoto
    JohnnyL
    Feb 11, 2022
    6
    In my case the Monster I was using (25-30 years old) was very brittle and just falling apart when you cut into it. It sounded like it looked.
