Hi folks. I know it's a contentious issue around here, but sadly I'm in the market for a decent speaker cable. Having been down the ruinously expensive Nordost route once before, I'm very reluctant to go down there again, but I know that the stuff is good. I'd prefer to find a reasonably flexible cable that doesn't sacrifice bass and midrange solidity for 'air' - but if I can get 'air' then great. I've looked into a couple of home-brew options, but want to draw up a shortlist to try to hear - including whatever's good at the moment. I need around 5m per side (or will do following a re-organisation of the room) and though the speakers are biwire I'm happy with a single wire and jumpers option (but only if the jumpers are the same type). Budget is notionally up to £200, but if a little extra buys a lot more, I can stretch. I'm keen to hear people's thoughts on the Eichmann speaker cables, though I expect they're outwith my budget - but having had great results with their connectors, I am wondering if it's worth springing for their speaker cables too. System is valve pre-power into biwirable 3-way floorstanders. Ta, John
