Hi All, I've recently bought myself a pair of B&W 686s, and was planning to wall mount them. My speaker cables are terminated with QED banana plugs, and I'd rather not chop them off, however this means they stick too far out the back of the speaker to mount easily against a wall. I've tried inserting them through the side holes, which I know is intended for bare wire, but wanted to check that this isn't going to cause any problems. [IMG]http://i16.photobucket.com/albums/b48/RPJ1983/connections.jpg[/IMG] Will I be OK using them like this, or am I likely to compromise sound quality from reduced contact area, and find they vibrate out later on? Cheers, Rich
