Within what range does the tweeters have to be level with your ears? I was supposed to be building some speaker stands today, but the PVC piping I was going to use seems quite expensive, and the build may not be straight foward as one would expect. So I might buy a pair of half decent commercial ones, (anything has got be better than what I have now) my only spec is that they must be the sand filling type so that they are more likely to be chunky. The height adjustable ones in Argos are a no no, (mine will be no worse) So back to my original question, my speakers are currently 95cm of the ground, but if I buy some I can only afford the 60m speaker stands, so it appears that I am stuck. Is it as vital to get your speakers at the right height as people and the magazines make out? EDIT: I've had idea use some threaded bars (the 12mm ones I didnt't use on my flexy) the only problem is they maybe to tall, but I've had idea for that. This will be a pretty cheap way of doing, and I already have the MDF bases from my old ones. I will use 3 legs on each stand.
