hi guys, i know this is a long shot, or perhaps wishful thinking, but what the heck i will ask anyway... if anyone knows, you wil... being unable to find a piccolo solo centre speaker, i am now looking for alternatives. one is, of course, having no centre speaker for the time being... but i started thinking if there was a temporary solution that didn't set me back too much. Also, because i need a pair of rear speakers, this idea came to mind... there must be a way to look at the speakers' technology and with it find a brand or make that will be more likely to work together with my signums... even if it won't be perfect... so here are the specs, let me know if you know what other brands use similar technology or you think may work well with this kind of technology (for either rear speakers or centres). The sonus faber signums specification is as follows: - 86db/w/m sensitivity. - freq response from 40Hz to 20Khz - 20mm silk dome tweeter - 150mm fiber glass multicoated cone mid/woofer - 6db/octave crossover @ 2.5kHz - 8 litres box with individual struts of solid walnut used for the outside and lead and copper parts used inside for resonance control. Would this help you guys have a rough idea of what other speakers use similar or compatible technology? Am I going about it totally the wrong way? :( Cheers, everyone! :beer: Jack
