Speaker wires
Discussion in 'DIY Discussion' started by Diesel Monkey, Aug 23, 2024.
  1. Diesel Monkey
    Diesel Monkey
    Aug 23, 2024
    6
    Hi All
    I'm new to hi-fi as I've just inherited a set up from someone but it come just as a basic setup. I'm trying to connect the speakers to a amp but can't find the correct cable so please help as I only have on speaker working
    I have a two pin connection on the speaker but a bare wire connection on the rear of the amp what should I buy.
    Thanks
  2. Diesel Monkey
    Sergeauckland
    May 31, 2012
    417
    84
    Suffolk
    Normal 5 amp 2 core lighting cable will do fine for up to about 5m length.
    S.
    Sergeauckland, Aug 23, 2024
  3. Diesel Monkey
    Diesel Monkey
    Aug 23, 2024
    6
    The problem is the speaker is not a bare wire connection it requires two cables with a crimped/sealed plug on one end and a bare wire connection on the other side
  4. Diesel Monkey
    Sergeauckland
    May 31, 2012
    417
    84
    Suffolk
  5. Diesel Monkey
    Sergeauckland
    May 31, 2012
    417
    84
    Suffolk
    Thinking about the above, are you referring to the loudspeaker end having DIN connectors? These have one wide flat pin and one thin round pin. If so, you can buy these on line, but they will need soldering. Depending on where you're located, I would be happy to do that for you, or any tech can do that.
    S
  6. Diesel Monkey
    Diesel Monkey
    Aug 23, 2024
    6
    Diesel Monkey, Aug 29, 2024
  7. Diesel Monkey
    Diesel Monkey
    Aug 23, 2024
    6
    Hi I need two cables with this plug on one end and bare cable's at the other end
  8. Diesel Monkey
    Sergeauckland
    May 31, 2012
    417
    84
    Suffolk
    Are you sure those plugs are for loudspeakers? Normally those RCA plugs are used for low level signals, not to drive loudspeakers. If they really are for loudspeakers, you have two choices, either make them up yourself, or buy an RCA to RCA ready made cable of the length you need and cut off the RCA plugs on one end and bare the wires. The problem with this is that RCA-RCA cables use thin wire, as they're only meant for low level signals, so they'll be quite fragile as 'speaker cables, won't carry much power, and if more than a few metres long, will have significant resistance.
    S
    Sergeauckland, Aug 29, 2024
  9. Diesel Monkey
    Diesel Monkey
    Aug 23, 2024
    6
    Hi
    Can I not just buy two RCA plugs and solder some speaker cable to them and make a cable up
  10. Diesel Monkey
    Sergeauckland
    May 31, 2012
    417
    84
    Suffolk
    Yes, of course, that's what I said above, you can make them up yourself.
    S
  11. Diesel Monkey
    Diesel Monkey
    Aug 23, 2024
    6
    Thanks
    I've ordered what I hope is the correct plugs it was knowing what they were called.
    Thanks for all your help
    Diesel Monkey, Aug 30, 2024
  12. Diesel Monkey
    vincenzapasquale
    Sep 5, 2024
    United States
    I've also ordered this one.
    vincenzapasquale, Sep 5, 2024
