okay, I've got the green light to set up a PC+squeezebox(es) system but I've got loads of questions which could do with loads of answers. Feel free to point out the obvious by the way as I may have assumed the wrong thing in some cases. :) [B]Hardware[/B] My PC I'm considering is an ex-work 700mhz, P11 (I think), 256MB Ram running XP. This will [U]only[/U] be used for music, nothing else (although it will be connected to the network for net radio etc.). I've got another PC which I'll use for the net and work stuff. - Is this an okay spec do you think? I'll be adding a USB2.0 PCI card to it and running an external hard drive, probably 250 or 300 Gb. I figured this would be okay as I've only got around 300 CDs - Any suggestions as to which drives are suitable/good vfm? Dabs have a Lacie 250Gb for £85. Is there a particular spec I should buy - cache size, speed etc. The network I'm going to set up will be wireless (I'm thinking of using the US Robotics router see [URL]http://www.dabs.com/ProductView.aspx?Quicklinx=3WNG[/URL] ) and the Squeezebox will probably be wireless too as the PC will be located some way from the listening room. Is there any consensus as to whether wired is better than wireless for the SB connection? Absolute sound quality isn't really the main thing - the main thing is not having dropouts. Any other hardware issues I should consider? [B]Software[/B] I was considering ripping the CD as lossless using Media Player 10. What do you reckon? I realise a lot of people use EAC and rip to .FLAC but is this better than using Media Player Lossless? If there is a good guide as to how to set all this up then I'd appreciate it. Cheers
