Squeezebox PSU
Discussion in 'Hi-Fi and General Audio' started by andyoz, Jan 25, 2006.
  1. andyoz
    andyoz
    Sep 18, 2004
    1,117
    I would normally have a go at it myself but I don't have easy access to any decent electronics shops so I tend to get everything over the web. It's a nightmare getting all the little bits needed to make even simple things.
    Plug-n-play it'll have to be.
    andyoz, Feb 13, 2006
    #21
  2. andyoz
    Heuer
    Sep 18, 2005
    37
    Seems someone has had good success with the Linear p 'n p supply from CPC/Farnell.
    Heuer, Feb 14, 2006
    #22
  3. andyoz
    The Moog
    Oct 15, 2003
    55
    Hitchin
    Is the Farnell linear PSU £20 well spent if you have a Squeezebox then? Anyone heard a noticable difference from the stock PSU? Cheers!
    The Moog
    The Moog, Apr 18, 2006
    #23
  4. andyoz
    DavidY80 Long Member
    Sep 22, 2003
    103
    Denmead
    I haven't heard the Farnell PSU you mention, but replacing the PSU can make a noticeable difference (even replacing the supplied PSU with another switcher!), and I would have thought it was worth a punt at £20.
    DavidY80, Apr 18, 2006
    #24
  5. andyoz
    zanash
    3,826
    Notts.
    Could be worth a punt ...rs do a nice one with variable voltage for about the same san's case work.
    zanash, Apr 18, 2006
    #25
  6. andyoz
    julian2002 Muper Soderator
    5,094
    Bedfordshire
    i use a replacement switcher from maplins - it's rated at 5v 4 amps and has an iec input. i seem to remember it being regulated too. couldn;t find it on the website again so i think they might have stopped doing them. there was a reasonable gain in performance over the standard wall wart but then i use some elephant cock power leads and a bada conditioner before it too.
    julian2002, Apr 18, 2006
    #26
  7. andyoz
    davidcotton prog rocker, proud of it!
    Jun 22, 2003
    182
    Dorset
    Did you get anywhere with which psu to use andy? Finally got my sb3 and qnap up and running, and can't believe how cheap the psu is!
    davidcotton, Apr 26, 2006
    #27
  8. andyoz
    Smithy
    Mar 10, 2006
    59
    The Decibel Dungeon SMPS has a 5volt capability,has anybody used one of these?
    Smithy, Apr 26, 2006
    #28
  9. andyoz
    andyoz
    Sep 18, 2004
    1,117
    Haven't actually purchased anything yet, but will just go with something simple like the one suggested in this thread and elsewhere:
    http://cpc.farnell.com/jsp/endecaSearch/searchPage2.jsp?Ntt=pw00187&Nty=1&N=411&Ntk=gensearch
    I have just ordered another two SB3's. Will be putting one in the bedroom with a set of these actives I got off eBay.
    http://www.jblpro.com/pages/recording/lsr25p.htm
    The other one will be going in the kitchen and I am thinking of using a Cyrus XPA amp (with Auto Power On sensing) and a set of 2nd hand bookshelf speakers.
    Have you got into the Internet Radio and Pandora yet?
    andyoz, Apr 26, 2006
    #29
  10. andyoz
    Jun 22, 2003
    182
    Dorset
    Still transferring files over to the qnap. The sb3s in the bedroom whilst the pc and net connections in another room. The original plan was to have had the qnap and sb3 in the bedroom. However after trying this last night the qnap is just and I do mean just the wrong side of loud for me. So I'm thinking a run of ethernet cable from room to room with it tucked under the carpet out the way will do.
    #30
  11. andyoz
    zanash
    3,826
    Notts.
    Your going to need better than that psu ?
    I would doubt that its any better than the stock unit. For a few pounds you could build one with a torroidal tranny, couple or four rectifiers, lm317 a cap ortwo and a nice case.
    zanash, Apr 26, 2006
    #31
  12. andyoz
    bec143
    Jan 22, 2004
    49
    The SB2 PS made a difference!
    I just got an Elpac 1.5 amp (I know it's a little too wimpy) linear power supply to play with. My immediate impression is that it has made a real difference on bringing my SB2 from OK to near my CD5/Hicap. Next step- a NOS DAC (Monica on the way).
    Maybe there is something to this after all!
    Bruce
    bec143, Apr 27, 2006
    #32
  13. andyoz
    zanash
    3,826
    Notts.
    That's a result..........!
    zanash, Apr 27, 2006
    #33
  14. andyoz
    Sep 22, 2003
    103
    Denmead
    There certainly is! I'm not a big fan of the NOS DAC's I've heard, but I do know that the Squeezebox can leave the CD5 a long way behind.
    Brush up your ebay selling skills, I've got a feeling you're going to be selling the Naim before too long.
    DavidY80, Apr 27, 2006
    #34
  15. andyoz
    bec143
    Jan 22, 2004
    49
    Maybe, but I'm still having some problems with wireless dropouts, although much improved. And I'm also not quite happy with options for storing my music on a dedicated external drive that can be accessed from my Mac laptop via iTunes. So these logistic issues will probably keep the CD player in the house.
    I guess the next step will be to see how much better it can get with a DAC of some sort. If it improves more, I'll be more inclined to try to make the swtich from CD
    Bruce
    #35
  16. andyoz
    bec143
    Jan 22, 2004
    49
    I know, it was a bit shocking overall!
    #36
