Stax UA7 Arm Lead
Discussion in 'DIY Discussion' started by Dick Bowman, Jul 8, 2005.
  1. Dick Bowman
    Dick Bowman
    May 24, 2004
    194
    I've just started a turntable refurbishment (more details later if it works out) - one of the things I want to do is replace the arm lead of a Stax UA7 arm.
    Are these things standardised in any way? I suspect that it's a plug/socket arrangement common to many Japanes arms of the time (1980-ish). Looks somewhat DIN-ish, 5 pins buried up in the arm pillar and sockets in the plug (if you see what I mean) - barrel diameter is about 12mm.
  2. Dick Bowman
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    Just sounds like a standard arm lead connector, many arms use that arrangement. Should be no trouble to replace.
    Anex, Jul 8, 2005
  3. Dick Bowman
    Dick Bowman
    May 24, 2004
    194
    Thanks, that's promising.
    The follow-up, of course, is whether it's possible to buy the plugs without cable. The one I have is moulded-on. I'd rather make up a cable than have to buy a full ready-made.
    Dick Bowman, Jul 10, 2005
  4. Dick Bowman
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    http://www.percyaudio.com/Catalog.pdf
    search that for 'tonearm plug' they're about $27. Not sure what they charge for shipping though.
    Couldn't find much else as I'm not 100% sure what they're called, miniature DIN I'd assume couldn't find anything
    Anex, Jul 10, 2005
  5. Dick Bowman
    Dick Bowman
    May 24, 2004
    194
    Thanks again, having established the principle that plugs can be bought separately I looked around a little, finding that Parts Connection lists them (and there's an outfit called British Audio that may take me down a closer-to-home route).
    Strangely enough, Parts Connection (and Percy) both seem to be selling plugs from Cardas, but I couldn't find the plugs on the Cardas site - where I'd looked originally.
    But first, some plinth-building...
    Dick Bowman, Jul 11, 2005
  6. Dick Bowman
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    I couldn't see them on british audio or parts connection, obviously wasn't looking hard enough. $27 seems expensive to me. Good luck anyway
    Anex, Jul 11, 2005
