Apologies for cross posting from PFM, but thius is really bugging me and hope someone will be able to help I've been noticing recently that the left/right balance when I've been playing vinyl seems to be off to the left and last night decided to get to the bottom of it. Thing is I got some rather strange results. Not trusting my own ears entirely (I am a little deaf in my left ear), I recruited Auntie Ants to confirm what I thought I was hearing, which she did. Cart is a Denon DL-160 on a Spacedeck/Spacearm. Amplification is a Densen Beat B-100 with Densens DM01 MM phono stage built in. Speaker cables Reson DNM (2x3m runs) into KEF Q55.2. I used the balance test on a Shure ERA III Obstacle Course test record. 1. Everything set up as is, the test record definitely was louder in the left than the right channel. Okay - I assumed at first bias might be the issue, but nope I can mess with that to both extremes - that just results in minor mistracking and wayward cueing and its still louder in the left anyway - So I thought "Is it the amp or phono stage or speakers"? . 2. CD doesn't seem to have this problem so if its the amp it must be in the phono stage. So I swapped the phono inputs round expecting to get either a louder right hand channel if the problem is upstream from the amp or the left channel remaining loudest if its the phon stage in the amp. Heres the strange bit - The test record showed the left/right balance to now be correct All be it, the wrong way round :confused: . 3. Next up I swapped the outputs to the speakers round (so that with both inputs and outputs reversed, the sound would come out the right way round) - the balance remained correct :confused: :confused: . 4. Finally I put the inputs back the way they should be and left the speaker outputs reversed - now the balance was wrong again - but louder in the right channel :confused: :confused: :confused: I must say I'm deeply confused. The way I've left it is with both inputs and outputs reversed so that the balance is correct and the stereo image is correct (also reversed the CD inputs - so that it doesn't come out mirrored). Any ideas? The bit I don't understand is when I switched the inputs - I'd have thought that wherever the issue is it should have either just swapped the balance or left the balance as was - which isn't what is actually happening. PS. Once I'd reversed all the connections and the correct balance was restored the stereo imagery improved hugely - as I guess you would expect ... Don't you sometimes wish you had a balance control? Help??
