Subs - are two smaller ones best
Discussion in 'Hi-Fi and General Audio' started by dreftar, Apr 26, 2006.
  1. dreftar
    6,766
    bucks
    Hi Joel!
    There's ''subs'' and ''subs'' !
    Revel are owned by Harman, and all the reviews I've read have said they used Harman's resources from pro JBL subs in the designing of the Revel range of subs.
    With EQ and software provided to integrate into a room, an inbuilt 1000w amp (!), and a cabinet/driver built by experts to sound good together I'm convinced I've made the right decision.
    I've no doubt I could have done it for a lot less with a home-brew version, but just like home-brew beer the results depend on the expertise of the brewer.. !
    Time will tell...
    bottleneck, May 2, 2006
    #61
  2. dreftar
    KUB3 ciao
    Feb 20, 2006
    278
    Are you saying a velodyne will have half the distortion / sound twice as tight as a top notch diy JBL sub?
    KUB3, May 2, 2006
    #62
  3. dreftar
    Stereo Mic
    Aug 30, 2005
    2,309
    For a given size, and at low enough frequencies/high enough levels, yes.
    The Velodyne DD series is concussive. The Revel is also excellent.
    I'd still prefer the DIY route for music though -just personal taste I guess.
    Stereo Mic, May 2, 2006
    #63
  4. dreftar
    KUB3 ciao
    Feb 20, 2006
    278
    Do you find velodyne to be too accurate?
    I have heard some bass which sounded very tight, but at the same time too dry and lightweight. Examples were: infinity 10", pg cyclone fan invention, plus some audiophile speakers.
    I want depth and real power to go with accuracy. The best I've heard so far is PMC transmission, as it's tight yet fun. I presume JBL may be in this vein?
    KUB3, May 2, 2006
    #64
  5. dreftar
    6,766
    bucks
    The PMC transmission lines I've heard (only 3 sets, admittedly) have been flabby and ponderous.
    I haven't heard JBL's (yet!).. but I'd bet my boots thats not what you would get. It doesnt reflect the reports I've heard anyway.
    The Velodyne I heard was tight, clean, powerful.. and with the room EQ seemed to seemlessly integrate, which is v important IMO.
    #65
  6. dreftar
    KUB3 ciao
    Feb 20, 2006
    278
    Interesting. The room placement is of course critical. I heard the PMC in a large room sounding amazingly tighter than anything else in stock - B&W, ATC, etc.
    Not heard velo as yet. Sounds like it should be better - in theory anyway
    KUB3, May 2, 2006
    #66
  7. dreftar
    Robbo
    2,371
    Berkshire, UK
    The Velodyne is suberb, very tight and capable of seamless integration. Highly recomended.
    But even more highly recommended is a pair of JBL studio monitors with 15" drivers. It's a different kind of bass to the Velodyne, the JBLs cant manage the depth and control in the very lowest octaves, but what they do in the midbass/upperbass between 80-300hz is phenomenal. I listened to deep purple Made in Japan at the weekend on a pair of JBLs and I have never, ever heard such realism from a domestic system. The kick drums were incredible with amazing definition, impact and speed. Just awesome.
    They totally and utterly destroy the PMC TL speakers IMO.
    Robbo, May 2, 2006
    #67
  8. dreftar
    Tenson Moderator
    Nov 12, 2003
    5,947
    I have found that generally any competent speaker (digs deep at reasonable level with low enough distortion) can sound very tight, as long as the room is good. It seems to be the dominant factor in tightness. Still, I guess you shouldn't trust my word on that, but I wont stop saying and believing it lol!
    Tenson, May 2, 2006
    #68
  9. dreftar
    dreftar
    Jan 3, 2006
    490
    Shetland Islands
    You cant alter the physics of it. Size does matter, the room that is......
    dreftar, May 2, 2006
    #69
  10. dreftar
    KUB3 ciao
    Feb 20, 2006
    278
    I've heard the same speakers sound amazing and poor in the very same room, just with different placements.
    KUB3, May 3, 2006
    #70
  11. dreftar
    Stereo Mic
    Aug 30, 2005
    2,309
    To a certain degree I agree Tenson, but you need to qualify the word competent.
    Take a look here at the distortion figures at high levels below 60hz. These are not bad - just typical of most domestic loudspeakers. Dedicated subwoofers from the likes of Velodyne, Martin Logan and Revel, will give massive improvements in the bottom octave and a half. Subs from the likes of Rel tend to measure as bad as, if not worse than the PMC's.
    But yes, even a good low distortion servo controlled subwoofer will struggle with room modes unless you take action to prevent it.
    Stereo Mic, May 3, 2006
    #71
