Sumiko Blue EVO3 Question
Discussion in 'Hi-Fi and General Audio' started by rega3, May 1, 2006.
  1. rega3
    kenneth cooke
    Feb 23, 2006
    37
    Yorkshire West Riding
    Hi I had one of these cartridges 3 weeks until I inadvertantly caught the stylus which is so so vunerable. Replaced it with a Micro Benz Ace which performs superbly and the stylus is much more protected by it's housing- be very careful
    kenenth
    kenneth cooke, May 3, 2006
    #21
  2. rega3
    JackOTrades
    May 15, 2004
    323
    Hamburg, Germany
    yes, these are fragile little things...
    one thing you can do to avoid inadvertedly damaging it is to keep the plastic cilinder that comes in the packaging around it when it is resting. it looks a bit like a plastic collar around it but it saves it from catching dust and adds a layer of protection (not very solid but better than nothing).
    i agree with alanbeeb... it seems bent to me, i have one on my Spacedeck and the cantilever line is straight as well coming out of the housing.
    hope it is fixable.
    jack
    JackOTrades, May 3, 2006
    #22
  3. rega3
    rega3
    Feb 19, 2006
    19
    Thanks again for the replies.
    The dealer i bought the deck from is sending me out a new cartridge so I will be able to see first hand what it should be like.
    I agree the cantilever is very exposed but just have to try to be careful with it!!
    rega3, May 3, 2006
    #23
  4. rega3
    lordsummit moderate mod
    3,650
    In the Northern Wastelands
    Indeed I learnt the hard way with my Lyra Dorian. I could have wept.....
    lordsummit, May 3, 2006
    #24
  5. rega3
    rega3
    Feb 19, 2006
    19
    £495!!- Ouch!! Was it your fault or someone doing you a favour of "giving your turntable a bit of a clean"!!
    rega3, May 3, 2006
    #25
  6. rega3
    3,650
    My fault completely, I'd bought it, fitted it, listened to it for an hour, then SWMBO was due to arrive home, England were ready to kick off, so I carefully slid home the guard, except the guard fits into two grooves on the body not to the top of the headshell. Result....
    One castrated Lyra. Luckily Direct Line coughed, and another appeared.
    Spoke to a dealer I know, he says most carts go in one of three ways, dusting, fitting the guard, or rushing to fit it in the excitement of something new.
    #26
  7. rega3
    Bradders
    Jun 7, 2004
    158
    London
    Or of course massive incompetence and fists made of ham.
    Bradders, May 4, 2006
    #27
  8. rega3
    Sid and Coke
    686
    East Coast Scotland
    Oi you, i resemble that remark. I've trashed two carts in the last 4 or 5 years, both incidents involved incompetence and ham fists..:)
    Sid and Coke, May 4, 2006
    #28
