Sumiko BPS Trouble (help!)
Discussion in 'Hi-Fi and General Audio' started by JackOTrades, Jan 23, 2006.
  1. JackOTrades
    JackOTrades
    May 15, 2004
    323
    Hamburg, Germany
    Hi Everyone,
    As you guys know I recently got myself a Spacedeck.
    I finally got the Rega OL upgraded and set on its rightfull place.
    I used first my Denon DL160 and worked fine.
    Then I put the Sumiko BPS in and it unfortunately I only get sound from one channel. I checked that all else is fine (arm wiring, phono stage) so it must be the cart. :(
    I was searching the forum for tips on carts and saw that Lt Cdr Data mentioned once that the Sumiko BPS being fragile was easy to fix.
    Any ideas if I can get it fixed, by whom, or otherwise any good replacement ideas?
    Thanks for any help!
    :beer:
    Jack
