Hi all... Won a VRDS 10 on ebay in "excellent condition" however, its won't play discs... Just opened her up to see what the mechanism does when I insert a disc. Looks immaculate inside. Found a clump of mangled white plastic that used to be the transit screw and removed it. Drawer opens okay, loads disc, display doesn't change drive initially lifts disc and doesn't spin. Press play it just retracts internally and drops disc. No sign of it spinning at all. In your venerable opinions, could this fault have occurred in transit or is it something like a servo board... Thanks chaps... It was immaculately packed, so I'm confused. I was a little narked yesterday when I wrote this, so felt more research was required before I unfairly lay the blame with the seller. It turns out they are very susceptible to impact from below or a knock on the drawer. The package can look fine, mine looked mint, but this model can still be easily damaged with sudden thumps, despite its chunky build. - bugger. :confused:
