The Cable Test - listen and decide
Discussion in 'Hi-Fi and General Audio' started by RobHolt, Aug 15, 2009.
I prefer......
  1. Cable 1
    0 vote(s)
    0.0%
  2. Cable 2
    3 vote(s)
    13.6%
  3. Cable 3
    2 vote(s)
    9.1%
  4. Cable 4
    2 vote(s)
    9.1%
  5. I cannot detect a difference
    15 vote(s)
    68.2%
  1. RobHolt
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    What are your recommendations, Rob?
    DavidF, Aug 21, 2009
    #61
  2. RobHolt
    RobHolt Moderator
    Oct 24, 2004
    No good describing things after the cables are revealed - it was a blind test.
    RobHolt, Aug 21, 2009
    #62
  3. RobHolt
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    You feel some memebers are placing too much empahasis on cables and should be looking into other areas instead, I was curious to know which areas you think?
    For your criticism to be valid surely thats a reasonable thing to ask?
    FWIW I would never pretend hat cables makes dramatic differnence. Subtle but definite is how I would describe them.
    It just depends, I guess, on whether you feel those improvements are worth having.
    Refering back to your post, Rob, I do agree that speaker placement makes enormous sonic differences. Is that what you meant?
    #63
  4. RobHolt
    RobHolt Moderator
    Oct 24, 2004
    For starters,
    -Sorting the room acoustics.
    -Understanding the way amplifiers drive loudspeakers - and not just enough power.
    -Proper sighting of components and in particular TTs
    -Using cartridges that don't distort horribly (>10% isn't uncommon at end of side!)
    - Tone controls - if the system is tonally off then correct it properly - swapping a bit of coax for a twisted pair is pissing in the wind for the vast majority.
    - Homework, homework, homework - don't just throw the reviewers choices together and then moan when it doesn't sound right, or turn up on a forum and say 'I've just put all this together and it sounds like shite, can someone suggest some wire to sort it' - pretty common post.
    #64
  5. RobHolt
    RobHolt Moderator
    Oct 24, 2004
    Yes, I was answering Spica but you posted in between.
    #65
  6. RobHolt
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Totally agree.
    (IME cables are about positive improvemnt not patching things up.)
    #66
  7. RobHolt
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    :MILD:
    #67
  8. RobHolt
    RobHolt Moderator
    Oct 24, 2004
    David, that's it, move towards the light, the wonderful bright light...... that's it keep walking....step out of the darkness :D
    #68
  9. RobHolt
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    #69
  10. RobHolt
    spica
    Aug 25, 2008
    310
    isotropic
    problem ? there's no change, just a fuller explanation :)
    spica, Aug 21, 2009
    #70
  11. RobHolt
    RobHolt Moderator
    Oct 24, 2004
    Worth a lot Martin!
    Spot-on.
    Donkeys years ago as a kid I lashed up some old passive pot in a box to drive the then Quad 405 mk1 at my Grandfathers.
    I had about 5m of cheap coax between the pot and the amp.
    Hi-Fi Answers at the time was raving about 'Archer Cable' - 300 ohm FM feeder cable available cheaply off the reel from Tandy.
    So I bought some, stuck some plugs on it and...... yup, more open and extended at the top end.
    Archer was about 15 puff pm while the coax was about 150 puff, so rolled off the top end.
    Didn't understand why back then so just assumed that the Archer was 'better' cable.
    Its why I bang on about people taking time to research the measurements and how to interpret them, in context as you say.
    Not doing so is poking around in the dark and risks being taken for a fool, and having the wallet lightened in the process.
    #71
  12. RobHolt
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    Now the fun with cable two is all very well and good, but I'm making a habit here. I chose the most expensive cable in this test, and correctly picked the lathed track the other week.
    Add that to my wonderful absolute phase sensitivity as tested on the Wam and I'm fast becoming 'golden eared'....
    sq225917, Aug 22, 2009
    #72
  13. RobHolt
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    Yes, a good approach.
    Sometimes you have to employ a division of labour and trust someone who know more about it than you.
    I don't beleive I'm being taken for a fool at all or have been, although I hear what you say.
    DavidF, Aug 22, 2009
    #73
  14. RobHolt
    Basil
    Jul 22, 2005
    222
    Outstanding!
    Basil, Aug 22, 2009
    #74
  15. RobHolt
    SteveS1
    Feb 7, 2007
    69
    Kent
    To be fair Rob, do you know many people who think cable differences are a priority? I certainly wouldn't begin to play with cables until I was happy with everything else.
    Not that I would seek to justify any such marginal differences as value. Mind you, nothing in Hi Fi could reasonably be considered vfm anyway. It's not that kind of hobby. Even the most basic rigs are expensive compared to what you can buy to play music in the home - it's only job.
    I happen to think the speaker/room interface is by far the biggest factor - but regularly get flamed by 80's flat earth "source first' fundamentalists. :D
    Steve
    SteveS1, Aug 22, 2009
    #75
  16. RobHolt
    6,766
    bucks
    Roy Gregory - are you reading this??? llollolollolololol
    bottleneck, Aug 22, 2009
    #76
  17. RobHolt
    6,766
    bucks
    rob thanks for all your efforts.
    I think equipment racks are another good one. I hypohthesize that equipment sounds the same on the floor or cheap furniture than it does on expensive racking. Perhaps a test will prove me completely wrong? I genuinely don't know on that one.
    #77
  18. RobHolt
    Jan 11, 2007
    1,514
    racking- for valve amps and turntables.... nuff said..
    #78
  19. RobHolt
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    I wouldn't flame you for saying that.
    The medical prefession go to great lengths to keep electronic stuff steady.
    I think it depends on whether you enjoy experimenting with materials.
    #79
  20. RobHolt
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    Yes they do, the equipment is normally well shielded from external interference and has a clean mains supply.
    However they do not utilise any type of special support, most medical equipment is on fairly flimsy trolleys so as it can be easily moved yo where it is required.
    Where I work we use active air suspension for isolation of measuring equipment. This is lazer measuring equipment that is accurate to .3 micron and the isolation is to help reduce any flex in the chasis between emmiter and reciever. It is not to isolate electronics, they are in a seperate enclosure and on a normal table.
    penance, Aug 22, 2009
    #80
