A distinctly small-scale, and hurredly arranged affair... The protaganists were myself, WM and Tim F. The main thing was the comparison of the NAD S300 with the Krell KAV300i, with a few other things along the way. Of course, we did a bit of cable swapping and so on, and the consensus seemed to be that at the end, when taking all of the cables out and going back to the original set of cables, that there was a clear difference, particularly with my DIY speaker cable that is clearly on the bright side. The krell looks distinctly unassuming when placed on top of the massive S300, although the front panel is rather livelier with a mixture of blue and red LEDs, buttons and graphics, but it is diminutive in size and weight relatively. And onto the sound.... The Krell's bass was certainly bigger than the NAD, although I felt that the NAD was deeper, faster and tighter. The midrange, almost suprisingly, was where the krell shone through a bit more, with good presence for vocals. The NAD was a little recessed comparatively, although from prior work and experimentation, I know that this is largely a room effect, which the krell seemed to get over rather better. Treble there wasn't a lot between the two. Perhaps a little harsher on the Krell, but not to the point that some people might believe. It was an interesting comparison, and neither amplifier disgraced itself. That the NAD is half the price (£1499 rrp, vs £2899) is impressive, although it is worth noting that the Gryphon Tabu Century, which is the donor design for the S300, retailed around £3000 or so. I think on balance, with what I know about the room, that I preferred the NAD for its musical approach. I think everyone agreed though that the room was doing no favours at all to the system with either amplifier. It will certainly be interesting to see how different things are after I've moved house on tuesday, when the system gets to be the primary occupant of the living room.
