The sound of digital audio replay software
Discussion in 'Hi-Fi and General Audio' started by Arkless Repairs, Jan 1, 2011.
  1. Arkless Repairs
    Arkless Repairs
    Dec 17, 2010
    57
    Has anyone else experimented with various software for replaying music from a hard drive on a PC?
    I've tried a variety of them. Foobar is very easy to use and freeware. Various other similar systems are around of course...
    I have found Adobe Audition to sound very noticeably better than any other software I've tried. All the others are very hard to tell apart to be honest!
    The key seems to be that Audition seems to take the time to process and "decode" the FLAC or WAV data before you can play it, whereas all the others seem to do it "on the fly" I.E. when you click on a track to play back it does not just play it. It takes 30 seconds or so processing it during which time the usual blue bar moves across a small window until it is ready.
    It has to be said that it is very awkward to use and if you just want convenience and ease of use then it's a non starter!! (it's pro audio recording and mastering software and not really designed to do a similar job to the likes of Foobar etc).
    If sound quality is the main (or only) consideration though then it seems to be the best.... for me on my system etc anyway.... its improvement seems repeatable on any of my PC's though.
    Any thoughts?
  2. Arkless Repairs
    Basil
    Jul 22, 2005
    222
    Do .wav files need decoding?
    Basil, Jan 1, 2011
  3. Arkless Repairs
    Arkless Repairs
    Dec 17, 2010
    57
    Good question. Audition still seems to take some time processing any type of format before playback though.
    Very awkward to use also as the only way of playing back an entire CD seems to be to batch process it so it becomes, in effect, one long track... which of course means you can't then decide to jump to track 6 for example. You would have to move the cursor to the gap of the silence after track 5 on the screen.
  4. Arkless Repairs
    Basil
    Jul 22, 2005
    222
    Adobe Audition costs $350? :eek:
    It damn well ought to sound better!
    Think I'll stick with foobar...
    Playing CDs on a computer, due to the way CD & DVD rom drives work is a pain, a noisy pain at that.
    Basil, Jan 1, 2011
  5. Arkless Repairs
    Arkless Repairs
    Dec 17, 2010
    57
    Yep it's not cheap.
    I don't really use my PC for playing CD's. I play from the hard drive.
  6. Arkless Repairs
    Tenson Moderator
    Nov 12, 2003
    5,947
    Audition is not a media player, it's a sound editor.
    Tenson, Jan 1, 2011
  7. Arkless Repairs
    Basil
    Jul 22, 2005
    222
    It's the only way to fly these days.
    What about differences between foobar & Winamp?
    I think foobar is better, but I can't see why it should be?
    Basil, Jan 1, 2011
  8. Arkless Repairs
    Arkless Repairs
    Dec 17, 2010
    57
    Yep, I said as much. That's why it's so difficult to use for this purpose.
    I shall compare foobar and winamp and let you know.
    It's hard to see why any should really sound different to any other as they are all just 1's and 0's! I reckon that AA does sound quite substantially better though.
  9. Arkless Repairs
    Tenson Moderator
    Nov 12, 2003
    5,947
    My suspicion is that, if they use the same drivers for the soundcard they will sound the same. Different drivers can produce different results though. In my system if I do distortion tests using direct sound, I can see some artefacts which are not there using ASIO.
    Tenson, Jan 1, 2011
  10. Arkless Repairs
    Arkless Repairs
    Dec 17, 2010
    57
    I'm using asio already and can still hear the difference.
    Arkless Repairs, Jan 2, 2011
  11. Arkless Repairs
    5,139
    Manchester
    Surely it depends on the exact codac the playback software uses rather than the software itself?
    amazingtrade, Jan 2, 2011
  12. Arkless Repairs
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    It depends on any number of things but at the end of the day if the software player has a bit perfect output then it can only be affected by jitter added to the signal due to bad clocking on the way off your pc. Potentially better software/drivers help reduce this by cutting any unnecessary background processes which might provide a better environment for the operation of the clock that feeds the output device.
    PC's are noisy places and getting data somewhere on time isn't really in their remit, just getting the right data to the right place in the right order.
    Codecs have nothing to do with playing back wav files, they are just raw pcm data in a wrapper, the pcm data is spat out via spdif/usb etc. Replaying anything else might be affected by the codec, but they should all provide the same value for the same data decode, any mp3 codec (version compatible) will give up the same music from the same data file.
    There isn't anything else going out to your dac from your pc except data and time/code, embedded or implied so jitter is really the only option if your player is bit perfect.
    sq225917, Jan 2, 2011
  13. Arkless Repairs
    chefren
    Jul 30, 2007
    17
    Finland
    Well Foobar doesn't whip the llamas ass like Winamp does! :D
    At least for MP3:s, the standard doesn't define in detail how to encode them so there could be differences in how programs create mp3:s. The standard does however state how to decode them, so there are no differences to be had there.
    It could be that if Foobar for example is setup to bypass Window's kernel mixer and Winamp is not, resampling is happening on the way and so the two players sound different. But this is down to setup really and not to the actual players as such. Also details like eq could be done in sufficiently different ways to produce audible differences in sound..
    chefren, Jan 2, 2011
  14. Arkless Repairs
    Arkless Repairs
    Dec 17, 2010
    57
    Just been trying another free one called VU player. Seems similar to Foobar all in all...
    Arkless Repairs, Jan 3, 2011
  15. Arkless Repairs
    Basil
    Jul 22, 2005
    222
    With the help of a friend, I did a blind test of winamp and foobar, I failed hopelessly!
    Three correct identifications out of 20 when I didn't know which was playing.
    Basil, Jan 3, 2011
  16. Arkless Repairs
    lAmBoY Lothario and Libertine
    1,233
    At home
    failed? you succeeded! You proved that there is no difference.
    lAmBoY, Jan 4, 2011
  17. Arkless Repairs
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    The ironic thing is that if Basil had just tried guessing he'd have achieved 50% success rate (theoretically).
    Dev, Jan 4, 2011
  18. Arkless Repairs
    Arkless Repairs
    Dec 17, 2010
    57
    Have not tried blind testing of Audition against others but the difference seems fairly marked to me... All others do seem to sound the same though!
    It would be interesting to know why Audition should be different?
    BTW. I have no connection or commercial interest in Audition! Thought I'd better point that out as I'm coming across as a salesman for them :D
    Arkless Repairs, Jan 4, 2011
    #18
  19. Arkless Repairs
    Jan 11, 2007
    1,514
    If it sounds different ti will be because it has some feature turned on that makes it sound different. I could go upstairs and try it, but what's the point, it has no special code to bypass the Kernel, so if it does sound different it's due to some digital processing.
    When audition was written there was no way round the kernel without asio4all and audition doesn't use it.
    sq225917, Jan 4, 2011
    #19
  20. Arkless Repairs
    Arkless Repairs
    Dec 17, 2010
    57
    "If it sounds different ti will be because it has some feature turned on that makes it sound different. I could go upstairs and try it, but what's the point, it has no special code to bypass the Kernel, so if it does sound different it's due to some digital processing.
    When audition was written there was no way round the kernel without asio4all and audition doesn't use it."
    I'm using Audition 3 which is I believe still the latest version. I am using it with ASIO.
    Arkless Repairs, Jan 5, 2011
    #20
