Roy Gregory of Hi Fi+ issue 38, says that the Linear A "is capable of a glorious, breathtakingly convincing musical delivery.....one of the biggest bargains out there in high-end audio land." Specs: A Hybrid class A single ended stereo power amp. This amplifier is a new precision design with extremely low distortion. Although the Linear is only rated at 25.2 watts p/c it is able to produce 150decibels of dynamic range. The output transformers have been designed to produce real power into loudspeaker impedances of 5 ohms and above. Recommended loudspeaker sensitivity of 87 db or higher. Purchased October 2007. Minimal use and in perfect condition. Offered at £2,495 (RRP: £4,400) Due to weight (approx 25kg) collection preferred (Tunbridge Wells).
