Toshiba 14" TV troubles
Discussion in 'General Chat' started by nsherin, Jan 22, 2005.
  1. nsherin
    nsherin In stereo nirvana...
    728
    Portsmouth, UK
    I have a Toshiba 14" TV that's about 1 and a half years old. It's suddenly started to give display problems, in the sense that when you switch on, any input from the SCART or RF connections simply becomes a rolling image and gets darker and darker, until you cannot see it. Is there any way to reset the TV or would I need to take it somewhere for repair?
    If so, what would it cost (roughly) to get put right? If it's more than £30, would you advise just buying a cheap portable from Asda or somewhere like that?
    Many thanks,
    Neil
  2. nsherin
    5,139
    Manchester
    It sounds like the virtical synch potemeter needs adjusting, this can be fixed quite easily but it means taking the casing off and of course you may get an electric shot if you don't know you're doing.
    If it just a pot adjustment then most repair shops should do it for about £10-£15 or so, it would only take me 1 minute to fix it. If its somthing else then I would just buy a new TV.
    Get a free quote and then decide. That TV is probably worth £30-£40 if it worked.
    amazingtrade, Jan 22, 2005
  3. nsherin
    728
    Portsmouth, UK
    Thanks - will take it down to the repair shop in the morning and see what they say.
  4. nsherin
    5,139
    Manchester
    I may be totaly wrong but I know there is an adjustment for that, I had a mate that used to fix a lot of computer monitors that did the same thing and I used to have a 14" TV which had a v-synch adjustment control to stop that rolling from happening. Manufactureres are crafty and put a lot of the potemeters inside the case so you have to take it to be repaired.
  5. nsherin
    728
    Portsmouth, UK
    The weird thing is that it appears fine for the first 2 or 3 minutes, then it starts playing up!
  6. nsherin
    smudge
    May 24, 2004
    57
    Hi
    Get a estimate by all means if you can or though there may be a charge for this, I don't think you could look at a repair for £30 although you might be lucky, I don't think on a modern t v there it would be a simple adjustment ( frame hold etc) more likely a jungle chip, you could get an idea by goggling the model number and wading through to get an idea of the sort of thing it could be, from you r description it could be something like in the video stages, frame, or sync separator, this would usually be all in one IC,I would just buy a new one.
    Stuart
    smudge, Jan 22, 2005
  7. nsherin
    728
    Portsmouth, UK
    Thanks Stuart. Managed to take it to a local shop that a few people I know have used and should be getting a free quote by Tuesday or Wednesday. Will see what happens from there.
