Anyone tried the new stand? Looks a bit expensive compared with the tss - twice as much?
How much better than the tss? For a grand I can get a SEM active isolation bench 2nd hand. Do you have any isolation specs of tss v vsss? thanks wadia!
For me, I perfer the VSS to the TSS, however they only remove the airbourne contaminatiom, you'll need to look else where for the internal component removal artifacts.
And the ground bourne too I assume ;-) Not sure that is a real problem with my kit - what would you recommend for the internal component removal artifacts? Its not something I have really thought about.
