Transcriptors T6 - Series 2
Discussion in 'Trade Adverts and Discussion' started by Transcriptors, Aug 25, 2008.
  1. Transcriptors
    Transcriptors
    Sep 2, 2007
    4
    Calverton, Nottinghamshire
    [​IMG]
    Specification
    Platter: 305mm machined aluminium disc fitted with five platter weights. The record is supported on soft poron rubber pads thereby reducing rumble and induced static to an absolute minimum.
    Plinth: CNC machined 20mm thick clear or black acrylic.
    Main bearing : Slim section ball-ended, ground silver steel spindle running into a one piece Delrin bearing assembly. No lubrication is required.
    Motor: Origin Live DC motor & Controller
    Power Requirements : 115vac or 240vac, single-phase, 50 Hz or 60 Hz.
    Speeds: 33.3 & 45 r.p.m.
    Wow and flutter: 0.01% at 33.3 r.p.m.
    Rumble: Not measurable.
    Tonearm: Origin Live OL1.
    Dimensions
    Width: 500mm
    Depth (lid closed): 400mm
    Depth (lid open): 500mm
    Height (lid closed): 178mm
    Height (lid open): 508mm
    Pricing
    £980.00 GBP
