Transformer
Discussion in 'DIY Discussion' started by T-bone Sanchez, Apr 28, 2005.
  1. T-bone Sanchez
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    Ive never wired a transformer before so I just want to check what Im doing. I have 6 wires; Red, Blue, Yellow, Green and 2 x Black. The two blacks are very thin so I presume they carry 12V. This is going to be a psu you for my phono amp. How do I wire this up accordingly?
  2. T-bone Sanchez
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    you need to check the manufacturer info, transformers dont go by a set colour scheme. (the 2 black could even be a temp sensor).
    penance, Apr 28, 2005
  3. T-bone Sanchez
    peranders More is better
    Apr 14, 2005
    47
    Göteborg, Sweden
    The very thin wires are probably the primary winding!
    peranders, Apr 28, 2005
  4. T-bone Sanchez
    blakeaudio
    Apr 14, 2004
    456
    London
    the could also be high voltage winding.... depends on the current as to the required gauge. i had a sowter power tranformer for the dynaco st70 i used to have that had the high voltage winding in a thin silver litz and the lower voltage high current winding in a big gauge solid core laqcured copper that looked like coat hanger wire... you really need the wiring diagram. the supplier should have included it. if not call them up and insist! you really don't want to mis-wire that!!!!!
    blakeaudio, Apr 28, 2005
  5. T-bone Sanchez
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    Ive just emailed them for a diagram and to find out were my centre bolt is! On the transformer it does say; 230V sw-sw, 12V rt-ge, 12V bl-gn.
  6. T-bone Sanchez
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    On the same subject, which rectifiers would you recommend??
  7. T-bone Sanchez
    avanzato
    Sep 20, 2003
    260
    Did you buy it from Maplin as it looks like you have a German made transformer the colours will make sense if you think in that language.
    230v 'primary' sw=black
    12v 'secondary' rt=red ge=yellow
    the other 12v 'secondary' bl=blue gn=green
    avanzato, Apr 28, 2005
  8. T-bone Sanchez
    T-bone Sanchez
    Feb 17, 2005
    1,411
    In paradise
    It is from maplins holiday camp and it is German. You are da man!
