After a recent house move, my Michell Gyrodec is playing up. The platter struggles to start, and when it does start the speed varies up and down slightly, causing pitch wobbles. The table it sits on is level, as is the deck itself - I've checked both with a spirit level. The edge of the platter isn't snagging on anything, the motor is fixed to the chassis so it can't have moved, and the belt is only a couple of years old and hasn't seen heavy use. (The previous belt lasted about 7 years). I tried removing the platter and adding oil to the hollow beneath it. This seemed to fix things briefly, then we went back to wobbly pitch. Does anyone have any ideas, please?
