i did a quick check through the threads, and i can't find anything that helps, so here goes... i need, urgently, a wall shelf for my turntable, but i can't find anything that looks like it will be wide enough... basically i need a shelf that's 500mm wide by 380mm deep, with about a 70-100mm gap behind the shelf to the wall. ideally it will not be domestically challenging, but it will be a massy shelf, and be able to support up to 100lbs. (potential upgrade...) any thoughts? everytime i think i have found something, i then realise it's to narrow. thanks in advance, eric.
