We have seen tests where users have been asked to judge the quality of equipment by comparing a recording of it's output to a direct copy of a digital source file. The recent Squeezebox test on PFM was interesting due to the low cost of the equipment. I think tests like the above mentioned are very stringent because not only are you comparing it to a pure digital source file, but you also include any distortions generated by the equipment used to record the item under inspection. However lets see how far we can take this... I have uploaded three files below. File A is a direct bit accurate copy from the CD. File B is played through my DAC, and then recorded by my ADC..... [B]ten times[/B]! So that means the file was played and recorded, that file was then played again and recorded again, and again and again... Each time the distortions of the equipment will build up, just like taking a copy of a tape from a copy. File X is a mystery, it is either the same as A or B. I'd appreciate if you would download each of the three files and listen to them on a quality system. Burn them to a CD if you can't play from the computer. Take your time to listen and don't feel any pressure to be right or wrong. This is a test of the equipment, not of you! Please then vote on which file you think X is the same as. Is it the pure digital rip or is it the the 10x recording? You may also vote if you are not sure. I'd like to add that I have no preconception about this test. I believe doing it once through the chain is inaudible... but ten times? I'm not so confident as it is a damn tough test! File A: [URL]http://www.mediafire.com/download.php?rexpdbblyec7oie[/URL] File B: [URL]http://www.mediafire.com/download.php?9aaxwazb6m5ugtz[/URL] File X: [URL]http://www.mediafire.com/download.php?bt745fafowf42mc[/URL] Please Note: This test is running on multiple forums. Please only vote on one forum as I will compile the results later. Also, the recording is 'We Added It Up' by 'My Brightest Diamond'. I hope no one will object to its use in this test but if you do, please let me know and I'll remove it.
