unusual single ended triode amps
Discussion in 'Hi-Fi and General Audio' started by bottleneck, Oct 12, 2006.
  1. bottleneck
    vibbles
    Feb 18, 2005
    66
    SW London
    My G'house ended up all blackgated and really sang, the Loftin White is a different thing all together, only 4watts with a beautiful open and detailed sound and a large soundstage, I prefer it to the 300b,
    my current project is a 45 SE which is supposed to be better than the 2A3, only 2 watts but who cares
    vibbles, Oct 12, 2006
    #21
  2. bottleneck
    Richard Dunn
    Jul 5, 2006
    1,198
    Sorry to be stupid but how do you put up pictures here.
    Richard
    Richard Dunn, Oct 12, 2006
    #22
  3. bottleneck
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    That is Nick G's if I'm not mistaken. A lovely sounding amp, though I haven't heard it for a while since I moved daan sarf so I'm sure its even better now. They're mercury vapour rectifiers like on the elecronluv amps- 1200V is too much for normal rectifiers to handle properly which makes flash over likely- a very scary thing with those volts. Nick was telling me that at those voltages even the ceramic valve base can conduct if you get a problem. Eeep
    Bottleneck: No I tried crossing a valve amp with an espresso machine, believe me the result ain't as pretty as that :) I ruined a perfectly good espresso machine too- thought it wasn't worth anything as I couldn't find the coffee pods anywhere, checked a month or so later and suddenly they're everywhere- could have got 600 notes for the thing on ebay:mad:
    Anex, Oct 12, 2006
    #23
  4. bottleneck
    Paul L vinyl and valves mostly
    May 29, 2005
    130
    Surrey
    Shame on you Anex, espresso machines come in pump or lever but not pods...
    Paul L, Oct 12, 2006
    #24
  5. bottleneck
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    Meh it was free- a place I worked at didn't even know they had it anymore so I inherited it. Made some pretty decent coffee actually as it was a proper pro job but designed for offices for some reason, there is one on a microsoft or IBM or something ad atm
    Anex, Oct 12, 2006
    #25
  6. bottleneck
    murray johnson
    Mar 23, 2006
    418
    7W all DHT all transformer coupled amplifier using 112's (80 years old) 71a's and 300B's. Tango NC16's NC14's and XE20 OPT's
    [​IMG]
    Still needs reg. psu fitting.
    murray johnson, Oct 12, 2006
    #26
  7. bottleneck
    6,766
    bucks
    hiya,
    you have pm!
    #27
  8. bottleneck
    Dik Dolan
    Mar 25, 2005
    129
    Thanks=)
    Dik Dolan, Oct 12, 2006
    #28
  9. bottleneck
    RobHolt Moderator
    Oct 24, 2004
    9
    You need to host the pictures on some web space or an online personal album and then link to them in your post.
    This place is good, has lots of capacity and is free:
    http://www.photobucket.com/
    RobHolt, Oct 12, 2006
    #29
  10. bottleneck
    Richard Dunn
    Jul 5, 2006
    1,198
    Thanks Rob - Pax ;)
    This is the amp I will take to bottlenecks, my SS SET competitor. Only power supplies fitted so far.
    Problem - it is so boring, shall I glue some milk bottles in it with LED's inside :D http://i100.photobucket.com/albums/m10/nenevalleyaudio/SETcomp.jpg
    I still can't seem to make it appear as a picture.
    Richard
    Richard Dunn, Oct 13, 2006
    #30
  11. bottleneck
    RobHolt Moderator
    Oct 24, 2004
    9
    Richard, on the photobucket site, just below your image, copy the text in the IMG box and paste it directly into your post.
    No need to use IMG buttons on ZG.
    The picture will then show at full size.
    RobHolt, Oct 13, 2006
    #31
  12. bottleneck
    Baudrillard
    Mar 7, 2005
    650
    Baudrillard, Oct 13, 2006
    #32
  13. bottleneck
    murray johnson
    Mar 23, 2006
    418
    I find their description of the sound of conventional DC heating to be very accurate. Dry, flat and colourless is what I hear. Trouble is, with very sensitive loudspeakers most ac heated SE amplifiers hum too much. The Tentlabs filament supplies have given me the best results to date. Has anyone else tried them?
    murray johnson, Oct 13, 2006
    #33
  14. bottleneck
    Baudrillard
    Mar 7, 2005
    650
    Some people biamp using a 45 amp for the treble and a different one for bass. The 45 is meant to be exquisite for treble, I believe.
    #34
  15. bottleneck
    Feb 23, 2005
    935
    Now it's hearing stuff like this that makes me very nervous about using 845 SET's (run at 1250v apparently). This, coupled with the fact that they're shoddy Chinese designed/manufactured amps with very limited QC, makes me wonder if I should really be using them at all.
    But they just make such a wonderful sound for £800....
    DT
    Dynamic Turtle, Oct 13, 2006
    #35
  16. bottleneck
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    Yes I was just thinking about that actually, not sure how they get away with it- could be to do with lower current draw- what output are the amps quoted as? I'd guess 20W but your probably only getting around 15? I think Nick's amp actually gives him 20 useable watts so that could be the difference. I shall find out and post back. But yes, that has always put me off tbh, something a bit smaller perhaps but the fact you can buy amps with 805's, 845s, 211s etc. on ebay for a few hundred quid seems a little worrying. I'd expect to pay more than most of them cost for the mains Tx alone really.
    Anex, Oct 13, 2006
    #36
  17. bottleneck
    esk
    Nov 9, 2005
    27
    Carissa time!
    [​IMG]
    Just put some KR845's in too.
    esk, Oct 13, 2006
    #37
  18. bottleneck
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    Looks like a little alien dog thing :)
    Anex, Oct 13, 2006
    #38
  19. bottleneck
    6,766
    bucks
    love the little glass chimneys! :)
    how do you find the KR valves? I notice they do a range, including 300b.
    bottleneck, Oct 13, 2006
    #39
  20. bottleneck
    esk
    Nov 9, 2005
    27
    But sounds like its kahoona's...:D
    esk, Oct 13, 2006
    #40
