Usb dac advice for pc use
Discussion in 'Hi-Fi and General Audio' started by oceanobsession, Mar 23, 2008.
  1. oceanobsession
    oceanobsession
    Sep 24, 2007
    131
    1. Which usb dac do i buy to use with my computer
    2. Is it best to use a dac or get a sound card for best sound
    3. Im told that cooling fans can cause problems with sound
    4. Basically how do you get the best sound using a computer playing music from its hard drive and maybe cd rom put through your preamp or is it best to use a dacpre like the benchmark model thanks all
  2. oceanobsession
    jcbrum Black Bottom fan
    Mar 22, 2008
    222
    Brum
    I use an RME fireface 400, as I prefer firewire to USB.
    A good device to experiment with is an Edirol UA25, it only costs £130 and several dealers and users have said it out performs many cdp's inc Naim and others.
    I would suggest a silent laptop as a hifi computer, maybe a MacBook,
    If you are experimenting with an older tower PC, then an M-Audio 2496 is very very good in terms of sound quality, and only costs £50.
    In my experience sound quality is not related to cost. All electronic equipment is cheap to manufacture these days, and you should get a lot of experience before spending large sums of money.
    iTunes is a good piece of software to start with, or you might prefer something like foobar if you're a bit techy.
    jcbrum, Mar 23, 2008
  3. oceanobsession
    oceanobsession
    Sep 24, 2007
    131
  4. oceanobsession
    Mar 22, 2008
    222
    Brum
    It's probably ok, did you buy it ?
  5. oceanobsession
    mhuk easily distracted
    Mar 24, 2006
    50
    Midlands
    MoodLab Dice is a USB DAC, supposed to be pretty good for the money, as is the iBasso. What's your budget?
    mhuk, Mar 23, 2008
  6. oceanobsession
    Mar 22, 2008
    222
    Brum
  7. oceanobsession
    oceanobsession
    Sep 24, 2007
    131
    Re usb dac advice
    Hello all. ive bought a edirol ua -25 which i think sounds as good or better than my arcam cd 192 which i will be selling if that is the case. i like the idea of a music server so that you can have a
    type of hand held unit that can select the music you will play
    do i stick with my current pc and add a sqeezebox or build another pc for music cheers oceanobsession
    oceanobsession, Apr 13, 2008
  8. oceanobsession
    Tenson Moderator
    Nov 12, 2003
    5,947
    I was really impressed with the Apple Airport Express Robert is now using, especially since it can be remotely controlled from his iPod Touch, giving album art and everything. Both the Airport and iPod Touch are wireless devices so you don't need the computer with the music server running in the same room. Better than the SB route IMO.
    The Airport has a digital output for use with any DAC you like.
    Tenson, Apr 13, 2008
  9. oceanobsession
    oceanobsession
    Sep 24, 2007
    131
    Re usb dac advice for pc use
    Tenson can the ipod touch play all music that is on your hard drive or is it only the music downloaded from apple and what formats does it play cheers ocean
    oceanobsession, Apr 14, 2008
  10. oceanobsession
    hifi addict
    Sep 26, 2006
    505
    Hastings
  11. oceanobsession
    Tenson Moderator
    Nov 12, 2003
    5,947
    The iPod Touch can work in two ways. It can act as an iPod, playing the music on its own memeory, and which while you are in the area of your wireless network, can also access all your music collection.
    Or, it can act as a control device for the main computer that is feeding music to your hi-fi wirelessly via the Airport. So in the latter case, it is not the iPod actually playing the music, it is just picking what tunes the main computer feeds to your system, and shows you the art and stuff.
    The web browser is also quite nice since if you are listening to some music, you can jump on the web and look up the lyrics, check the forums etc.. all on the little iPod Touch (which has a reasonable size screen). If I didn't have a computer in my listening room already, I would want one of these iPods!
    Tenson, Apr 14, 2008
  12. oceanobsession
    Dick Bowman
    May 24, 2004
    194
    Just so's to understand this new technology...
    I have a heap of files on a network drive, which contain music (mostly MP3 format).
    I can play them back on my laptop, and revel in the sound of its inbuilt speakers.
    Now I want to be able to hear them on my proper sound system.
    Is it as simple as "buy an Edirol UA24, connect a suitable wire between the USB sockets on laptop and UA25, connect a suitable wire between the UA25 audio outlets and my preamp, select a file, listen to it"?
    Looking for a minimalist solution, don't want to look at album artwork or anything else - just choose a file and get sounds from my grown-up speakers.
    Is the Edirol "it", or are there equivalent devices?
    Dick Bowman, Apr 15, 2008
  13. oceanobsession
    Tenson Moderator
    Nov 12, 2003
    5,947
    Correct Dick.
    There are other devices. The Edirol is a good budget option though.
    Tenson, Apr 15, 2008
  14. oceanobsession
    Dick Bowman
    May 24, 2004
    194
    Thanks for that - I'm still a little puzzled.
    What's the role of a Squeezebox? As I understand it I don't need one, yet "everybody" (who was doing this computer-to-stereo thing a few months ago) seemed to have one.
  15. oceanobsession
    Tenson Moderator
    Nov 12, 2003
    5,947
    The squeezebox would connect to your hi-fi like any other source, but it gets the data from the computer wirelessly. This way you don't need to use the computer directly (or have it in the same room) to pick your tunes.
  16. oceanobsession
    Dick Bowman
    May 24, 2004
    194
    Thanks - I suspect I'm in one of those "I didn't realise it was as simple as that" scenarios.
    Dick Bowman, Apr 16, 2008
  17. oceanobsession
    Tenson Moderator
    Nov 12, 2003
    5,947
    It does get a bit more complicated the the practicality of making it all work, such as the software you need to run on the computer and setting up a wireless network and so on... but that is the jist of what the things do.
    Tenson, Apr 16, 2008
  18. oceanobsession
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    while we are asking then Simon, i'm curenetly using a pretty shitty £7 usb-optical convertor, between laptop and DAC.
    All i want is a shit shot USb box capable of passing through 44.1-192kh upto 24bit as thr dac willl take that.
    any suggestions, not interested in other features, just bitperfect optical out from usb input..
    sq225917, Apr 16, 2008
    #18
  19. oceanobsession
    Tenson Moderator
    Nov 12, 2003
    5,947
    Apart from getting an external soundcard, I'm not sure what the best option would be. Does the £7 thing not cope with higher bit rates and sample rates then?
    Just 'cos its £7 doesn't mean its not bit-perfect! Does it sound decidedly bad? It does seem a bit of a long shot to get anything reasonable for that cash.
    Tenson, Apr 17, 2008
    #19
  20. oceanobsession
    Jan 11, 2007
    1,514
    it sounds ok. But it doesn't sound better than my cd player spinning the disc and using the DAC.
    I'm pretty sure it reclocks half dvd whatever that is.
    it is noticably worse than my old laptop just using its optical out into the dac.
    In reality it just two clocks and and a reciever chip spdif to opt convertor, theres no real reason it can't be put together for pennnies, this one obviously was. It just like the M-audio transit, but cheap.
    External soundacrd would be good, any suggestions for decent ones.
    sq225917, Apr 17, 2008
    #20
