Used pre/power recommendations under £1000
Discussion in 'Hi-Fi and General Audio' started by kora, Sep 13, 2005.
  1. kora
    kora
    Sep 13, 2005
    3
    I'd appreciate any suggestions for a second-hand pre/power combination under £1000 that would work well with an Arcam FMJ CD23 and Epos ES22 speakers, the intention eventually being to triamp.
    kora, Sep 13, 2005
  2. kora
    alexs2
    Dec 15, 2004
    206
    You may find things like the Rotel 1075(a multichannel amp) to be useful,esp if you're intending to triamp at some stage.
    The amp itself is well made and powerful,and for the current used prices,represents good value.
    You could also consider some of Arcam's own pre/power amps,which also have fairly decent used prices,and would go well with your current system.
    alexs2, Sep 13, 2005
  3. kora
    julian2002 Muper Soderator
    5,094
    Bedfordshire
    have a look at some old olive naim gear.
    pre's 32.5, 72, 102, 112
    powers 110, 140, 160, 180, 150
    you may even be able to afford a *cap psu of some sort if you find a bargain. once you have the *cap you can triamp very easily.
    also take a look at some of the chinese offerings.
    i can reccomend vincent's sp t-100 mono blocks and i'm sure their pre is pretty good too.
    julian
    julian2002, Sep 13, 2005
  4. kora
    anon_bb Honey Badger
    May 30, 2005
    2,804
    avi? you can get a pre and monoblocks for that much second hand. they sound good.
    or go diy - wnaudio.com. he can supply prebuilt if you find soldering daunting.
    anon_bb, Sep 13, 2005
  5. kora
    ditton happy old soul
    Sep 18, 2003
    1,261
    Edinburgh
    I drive my epos es22s with a bridged bel canto evo4. had much discussion with folk here about this, but proof was in the listening. Bi-bridging (bridge at the poweramp and bridge at the speaker) was much preferred to bi-amping.
    If you go the bc evo way, then its all about the pre, and I have dumped the pre by going direct from my Dax Decade.
    ditton, Sep 13, 2005
  6. kora
    alexs2
    Dec 15, 2004
    206
    Very interesting,but also worthwhile point about going direct from CD to power amp,via an attenuator,which I've done also,using an Audio Synthesis Passive pre.
    It can make very noticeable gains in sound quality,and very easily done if you're using CD as a source.
  7. kora
    Sep 18, 2003
    1,261
    Edinburgh
    I know that an evo4 is much more than a grand, but its purchase means that you dont have to shell out on extra amps to bi/tri-amp.
    I understand that the AS passive enjoys good rep.
  8. kora
    Stereo Mic
    Aug 30, 2005
    2,309
    Why not get an integrated? At that price you will end up with a better amp in my opinion.
    Passive triamping is pointless isn't it? Just get a decent amp in the first place.
    Stereo Mic, Sep 13, 2005
  9. kora
    analoguekid Planet Rush
    Nov 14, 2003
    2,189
    Paisley Scotland, UK
    What he said ^^^^ unless you can find an old DNM pre power or somesuch, up your budget to £1500 and the primare pre/power and amps of that calibre becoe available.
    analoguekid, Sep 13, 2005
  10. kora
    kora
    Sep 13, 2005
    3
    I know that there was a considerable improvement in what I was hearing when I added two 8P power amps to an Arcam 8 integrated, maybe the gains are more obvious at this end of the scale.
    kora, Sep 15, 2005
  11. kora
    maddog 2
    Jul 16, 2003
    319
    Densen B200/B300
    not sure about the triamp thing though.
    maddog 2, Sep 16, 2005
  12. kora
    Markus S Trade
    1,527
    Nether Addlethorpe
    I'm currently using a chrome bumper Naim 32.5/110 combo. Really nice. Based on this, a good and cheap way to get to a 3-amp system could be old Naim.
    Markus S, Sep 16, 2005
  13. kora
    Alex S User
    Aug 16, 2003
    588
    Seconded.
    Alex S, Sep 16, 2005
  14. kora
    Garmt
    Apr 26, 2005
    557
    Either Denson or NAIM will indeed work well. I have heard Epos also go VERY well with a modified Quad 405!!
    Garmt, Sep 16, 2005
  15. kora
    The Devil IHTFP
    Aug 13, 2003
    4,613
    Disco Towers
    Naim 32.5 or 62, plus NAP 140, plus hicap.
    The Epos speakers were designed using the NAP 250 as the reference amplifier, and they work very well with Naim, as one might expect.
    Forget about biamping, etc.
    The Devil, Sep 16, 2005
  16. kora
    Mr Perceptive
    Aug 25, 2003
    135
    Mid Wales
    Bit leftfield but maybe smoother than the Naim suggestions, but still capable of good current driving into difficult loads. Meridain 501/557 ?
    Mr Perceptive
    Mr Perceptive, Sep 16, 2005
  17. kora
    Gromit Buffet-blower
    May 4, 2004
    345
    Darkest Lincs
    I recently picked up an Exposure IV Dual-reg power amp and dual VI/VII psu/pre for about 700 quid and all in superb condition.
    Exposure are now servicing the old gear so something like this is now a safe bet 2nd hand.
    Exposure & Epos are match made in Heaven.
    Gromit, Sep 16, 2005
  18. kora
    Garmt
    Apr 26, 2005
    557
    Yep, Exposure is also said to be very good with Epos. I bet Lavardin might be as well...
    Garmt, Sep 16, 2005
    #18
  19. kora
    kora
    Sep 13, 2005
    3
    Is there enough time for Naim I wonder. I'm getting on a bit.
    kora, Sep 16, 2005
    #19
