I recently bought a Bel Canto SEP-2 valve preamp ([URL]http://www.goldmanaudio.com/goldman/productmfg.asp?sku=7[/URL]) 2nd hand. It's been internally upgraded to SEP-1 status. It sounds great and worked fine to start with, but over a period of a month or so the balance started to skew to the left. Interestingly, the device itself seemed to detect this bias as when you switched it on, the (microprocessor-controlled) balance control would automatically be set to the right in compensation. If you reset the balance control back to "centre" position, the sound would be clearly offset to the left. This effect seemed to get gradually worse over time. At first it was barely noticeable, but by now it's very obvious. The "automatic compensation" of the balance control seemed to react accordingly, initially just setting itself one or two "ticks" to the right on startup, and by now setting to the maximum (6dB?) setting to the right, though this isn't enough to compensate for the effect anymore. I've tried swapping tubes and the effect remained, so it's not simply dying tubes. Can anyone think of anything else that might cause this? Is there anything I can do to fix it? It's clearly out of warranty, so if I can avoid the cost and hassle of shipping it back to Bel Canto in the US for servicing I'd be very grateful! Any thoughts or advice would be greatly appreciated! Cheers, Dunc P.S. - Sorry for crossposting on PFM, but I'm rather desperate!
