Vintage Hi-fi
Discussion in 'General Chat' started by nando, Dec 7, 2013.
  1. nando
    Tenson Moderator
    Nov 12, 2003
    5,947
    I'm not sure I can make this week Wed as I have an order to get out asap. How about first week Jan?
    Tenson, Dec 16, 2013
    #21
  2. nando
    RobHolt Moderator
    Oct 24, 2004
    9
    How about Friday 3rd jan?
    RobHolt, Dec 17, 2013
    #22
  3. nando
    nando nando
    Jun 1, 2006
    4,017
    london
    hi guys, are we still on :)
    nando, Jan 8, 2014
    #23
  4. nando
    Tenson Moderator
    Nov 12, 2003
    5,947
    Yes, but I'm moving on the 18th so it will need to be a little time after that. How about 25th?
    Tenson, Jan 8, 2014
    #24
  5. nando
    nando nando
    Jun 1, 2006
    4,017
    london
    quote
    it's ok with me, how about dev and rob?
    nando, Jan 11, 2014
    #25
  6. nando
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    I think I can make the 25th.
    Dev, Jan 11, 2014
    #26
  7. nando
    nando nando
    Jun 1, 2006
    4,017
    london
    what time guys?
    nando, Jan 14, 2014
    #27
  8. nando
    Tenson Moderator
    Nov 12, 2003
    5,947
    Rob said he can make that date too. How about 1pm? I'll be travelling from Gravesend.
    Tenson, Jan 14, 2014
    #28
  9. nando
    DSJR
    Sep 1, 2007
    96
    Hmmm Rob! 774, the arm made with often horrible sticky or rattly bearings, castings that looked disgusting, Allen bolts that were often rusting on delivery and a later exit cable that beat many suspended belt drive decks....... Ghastly thing to use as well, the lift-lower often not staying up and counterweight decoupling that sometimes sagged over the years. Mission decided to direct couple the counterweight later on - a bit of an about face in my view....
    It is possible to have a very rosy view of some vintage products (like I do of the Quad 33, which looks fab but with original if modified circuitry is still way behand what a pair of modern IC's can offer) and I do appreciate the surviving 774's should be ok after thirty plus years - and it CAN perform very well, but a Rega RB series arm, even the brass-n-Loctite 250 based models, can see off a 774 most of the time if they're set up right using an armboard that suits the more solid build (in other words, preferably not a metal one in my experience).
    Apologies, had to dive in there - old age you know ;)
    DSJR, Jan 14, 2014
    #29
  10. nando
    RobHolt Moderator
    Oct 24, 2004
    9
    Hmm indeed. I've owned three of them, one in 1980, one about 5 years ago and one now. All fine on all counts. The bearings are heavily pre loaded and will have survived better than contemporary design such as the Ittok and Syrinx PU models. I've even dropped a 774 onto a hard floor and it survived fine so they are more robust than they look.
    The very first versions with the heavy grey cable and circular shaped corners to the mounting plate were rougher castings.
    The later ones using the more traditional shaped SME plate were of much cleaner build.
    A 774 eats an RB alive IME. Ironically it's more 'Rega' in design ethos than any RB series arm. The Rega's are good but sound a bit dull and leaden next to a 774 which pushes things along with more zing and zest, accurate or not. Cleaner top end though on the Rega arms.
    I have both counterweights and yes I agree the solid type is down to Mission not understanding what the design was about..... The 774 was sold by Missionas their product but is entirely a John Bicht design and was produced exactly as his plans and patent stipulate. After Bicht left the uk Mission revised the arm slightly and offered the solid counterweight.
    Fresh sorbothane can be fitted today in place of the original stuff which is turning to goo after all these years.
    OTOH I've seen plenty of SME 3009s with saggy stems, loose bayonet sockets, rattly horizontal bearings, gummed up lift devices etc.
    So I think the ageing of arms - assuming they worked properly when new - is pretty much luck of the draw.
    They all contain interference fit parts, rubbers and oils so all will need some TLC after 30 years.
    If you're coming to the Scalford show you can hear the 774 on one of your favourite TTs, the SL150 :)
    RobHolt, Jan 14, 2014
    #30
  11. nando
    nando nando
    Jun 1, 2006
    4,017
    london
    hi simon, 1pm will be fine, is dev ok with that?/
    nando, Jan 14, 2014
    #31
  12. nando
    Dev Moderator
    5,764
    4
    Ilford, Essex, UK
    Yes.
    Dev, Jan 14, 2014
    #32
  13. nando
    nando nando
    Jun 1, 2006
    4,017
    london
    looking foward to that, thank you,
    nando, Jan 18, 2014
    #33
  14. nando
    RobHolt Moderator
    Oct 24, 2004
    9
    Joseph, what's your favourite tipple these days?
    RobHolt, Jan 18, 2014
    #34
  15. nando
    nando nando
    Jun 1, 2006
    4,017
    london
    Quote
    HI ROB, FULLER'S ESB, THANK YOU, GOES NICE WITH MUSIC.:)
    nando, Jan 19, 2014
    #35
  16. nando
    nando nando
    Jun 1, 2006
    4,017
    london
    Hi Guys, Are We Still On For Today?
    nando, Jan 25, 2014
    #36
