vinyl distortion and cone flap - help!
Discussion in 'Hi-Fi and General Audio' started by midlifecrisis, Oct 20, 2005.
  1. midlifecrisis
    midlifecrisis Firm member
    Nov 1, 2003
    537
    Suffolk
    My vinyl set up (Gyro Se, Techno arm, Ortofon MC15, Diablo) was working fine until recently. I'm now getting distortion and a horrible cone flap, where the bass cones pulse in and out wildly on the record run in. I did have one clumsy pick up incident where the needle slid across a record, but can't think of anything else that's happened or changed to give rise to this, and visually the cantilever etc still look OK. I loathe vinyl set up tweaking, so before I start taking off and resetting up the cartridge etc, is there any likely cuase that I should be looking at first? As I said, this didn't happen when first installed, so it's not something inherent in the equipment like cartridge/arm mismatch.
  2. midlifecrisis
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    Cone flap is quite common if you don't have a subsonic filter, unless they're about to fall off its fine.
    Needle sliding across shouldn't have hurt it really unless the mounting bolts were loose or something, I'd check alignment first
    Anex, Oct 20, 2005
  3. midlifecrisis
    lordsummit moderate mod
    3,650
    In the Northern Wastelands
    You could do to have a really good look at the stylus, can you take it off, or is it an all in one?
    Get it in really good light, and use a magnifying glass, you might be able to see any obvious damage. It does sound like damage to me if you're getting distortion. i don't think the cartridge body will have moved. Have you tried giving it a really good clean?
    lordsummit, Oct 20, 2005
  4. midlifecrisis
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    Its happened to me before, if its miss-aligned it can distort, took me ages to track it down. That why I'd check everything before taking it off.
    Anex, Oct 20, 2005
  5. midlifecrisis
    Paul Ranson
    Sep 4, 2003
    1,602
    An octopus's garden.
    It may be common but it's not fine and shouldn't occur.
    You need to examine the stylus, if the cantilever looks straight then it's probably OK. But you may have chipped or damaged the stylus.
    Failing that perhaps you've had a coincident failure of the MC input on your amp? Is this both channels?
    Paul Ranson, Oct 20, 2005
  6. midlifecrisis
    Nov 1, 2003
    537
    Suffolk
    Thanks for the advice. It's a new symptom - ie it didn't happen on the same records a couple of weeks ago, so definitely a change somewhere rather than lack of subsonic filter. It does affect both channels. Both amp and phono stage are less than 6 months old so I'd hope it's not a fault there. Sounds like I should look at the stylus first, then realign the cartridge. God, I hate doing that stuff!
  7. midlifecrisis
    Dec 5, 2003
    1,928
    East Midlands
    Its as much a question of confidence as anything. Be careful and methodical and you will be fine.
    Uncle Ants, Oct 20, 2005
  8. midlifecrisis
    Feb 23, 2005
    935
    I though RIAA phono stages have sub-sonic filters built into their equalisation curves anyway???
    Dynamic Turtle, Oct 20, 2005
  9. midlifecrisis
    Dec 5, 2003
    1,928
    East Midlands
    Some do, some don't.
  10. midlifecrisis
    TonyL Club Krautrock Plinque
    1,613
    Another pink world
    Cone flap happens if you get the arm mass / cartridge compliance maths wrong, i.e. a too massy arm for a cart's compliance rating. As yours was once right and now, after an accident, isn't one of two things has happened: a) you have broken the cartridge (i.e. made it more compliant by damaging the mechanical workings) or b) you have accidentally knocked the tracking weight up much too high. If it isn't b), which is easy to check, then it is a) and the cart needs replacement.
    Tony.
    TonyL, Oct 20, 2005
  11. midlifecrisis
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    so have I always been fobbed off with it happens with ported speakers then?
    Anex, Oct 20, 2005
  12. midlifecrisis
    1,613
    Another pink world
    It is more noticeable with ported speakers as they are freer to make large excursions, but the math is the same. The only other reason for cone flap that I missed earlier are decks, especially suspended ones on wobbly supports, i.e. a LP12 on a stand on loose floorboards will flap the cones if you walk over the floor as it simply can not deal with the lateral movement.
    Tony.
    TonyL, Oct 20, 2005
  13. midlifecrisis
    Anex Thermionic
    Feb 18, 2005
    1,434
    London
    Shouldn't be that, I'm wall mounted. According to the morch table thing I have the correct arm tube for my cart, downforce is well within what it should be
    Anex, Oct 20, 2005
  14. midlifecrisis
    1,613
    Another pink world
    When do you see the cone flap? If it is just on significantly non-flat vinyl then that is largely acceptable.
    All you need to calculate it is this graph:
    [​IMG]
    The mass figure includes the arm, cartridge and mounting hardware. Blue is good. The goal is to keep the resonance below the audio band and above warp frequency and any subchassis suspension the deck may have.
    Tony.
    TonyL, Oct 20, 2005
  15. midlifecrisis
    badchamp Thermionic Member
    680
    NW London
    IIRC our esteemed Mr Saab put a thread up on this very matter a little while ago. May be come pointers there.
    Jeff
    badchamp, Oct 20, 2005
  16. midlifecrisis
    Nov 1, 2003
    537
    Suffolk
    all I had time to do tonight was to give the stylus a good clean and tighten a bit the collar where the arm goes into the arm board (sure there's a technial term for it...) which was very loose. I also recentred the motor standing inits cut-out hole - I thin kthis might have been what cuased the flapping as any lateral movement would have brought cotnact... the cones no longer flap but there is quite a strong channel imbalance, with not much coming through the right channel (still a phono issue as the cd works fine). connections are all good, so maybe I'll need to realign the cartridge - I'll give it a go tomorrow night
