warm, smooth amp recommendations pls
Discussion in 'Hi-Fi and General Audio' started by jazzpioneer, Apr 9, 2009.
  1. jazzpioneer
    DavidF
    Mar 31, 2006
    3,296
    Shropshire
    There you go!
    DavidF, Apr 12, 2009
    #21
  2. jazzpioneer
    zeabre
    Sep 21, 2008
    Very nice speakers...had the S5s, now running the SA1. As far as amps go, I have Quad IIs, revamped, but prefer my Primare I30...Spendor Primare combination has exactly the sound I think you'd like.
    zeabre, Apr 12, 2009
    #22
  3. jazzpioneer
    Nomoretweaks Tourist on tilt
    Dec 9, 2004
    265
    Richmond
    Are you sure you need a "warm" amp? For Hendrix ?? I imagine you lower the level with your current amp and it sounds thin, that's why you need a warmer one..Am I correct? If you are looking for a right balance at low levels it is not nesessray a "warm" one, which will do the trick, although some warmer sounding amps will give you an impression of a more "balanced" sound at low levels. But it might be just an illusion, and you will soon realise that there is a lot of information missing further up the freq. range. I would look for an amp with a "quality first watt" so to speak. Valves are an obvious choice of course, but there are some, albeit few, SS amp which are good in this dept. due to their circuits. One relatively cheap I had, which sounded excellent at low levels was Lavardin IS, although rare, you can find it for well under 1,000 used. I would actually second Quad 306 - but only with a decent valve preamp - a cheap EAR (what was its number - the small black box, the cheapest one ? 834L ?). 306+this preamp with NOS valves sounded surprisingly nice in my system at low levels. But changing stock valves would be paramount imho.
    Nomoretweaks, Apr 13, 2009
    #23
  4. jazzpioneer
    RobHolt Moderator
    Oct 24, 2004
    The 306 is a nice little amp without sonic character IMO. Best way to make it sound warm is to pop a 34 in front of it and flip the tilt control. Not fashionable but it'll do the trick.
    RobHolt, Apr 13, 2009
    #24
  5. jazzpioneer
    jazzpioneer
    Apr 9, 2009
    9
    London UK
    Yep - bang on. My current amp sounds great when I crank it up....
    This is a great forum - should have joined a long time ago! Many thanks for everyone's input. More always welcome!
    jazzpioneer, Apr 13, 2009
    #25
  6. jazzpioneer
    Coda II getting there slowly
    Nov 17, 2004
    603
    Devon
    Been having a bit of a swap around with amps over recent months and am in a not dissimilar position wrt under four sleeping directly above speakers and have, like a number of posters, never made things over quiet.
    Current set up is Croft Micro25 pre (on loan) with Sugden A21aP power. I did for some time think of a valve integrated or power, but having tried a few, decided that the issues they brought in terms of usability and safety for the whole family were not outweighed by a sufficient improvement in enjoyment. The amp combination above seems to me at the moment to do enough to suggest that a valve pre/ss power is the most viable long term solution for me.
    The Sugden replaced a Quad 909 - direct descendant of the 306 and, while I wouldn't disagree with what has been said up thread, for me the Sugden does do significantly better at tonal colour - without being obviously coloured - and at lower levels I think that makes a big difference. The Croft is currently replacing a TVC pre and it doesn't have the top end crispness that the TVC does but whereas in the past I have missed that aspect when trying other pres, the Croft seems to bring so much else that the current sound is complete in itself.
    Lastly this combination never comes across as 'loud' even when the volume control is treated with abandon - it just gets bigger.
    Coda II, Apr 14, 2009
    #26
  7. jazzpioneer
    larkrise Sheepdogs prefer red wine
    Mar 12, 2005
    735
    Without doubt one of the best valve preamps I have come across for a long time has been the Graaf pre's. In particular a WFB One which i thought had the edge on a 13.5 MK2 which costs thousands more. It has exactly the sound you are after. I managed to find one recently - outstanding and a superb phonostage too.
    larkrise, Apr 16, 2009
    #27
