What amp for £250 new or used?
Discussion in 'Hi-Fi and General Audio' started by amazingtrade, Nov 26, 2010.
  1. amazingtrade
    5,139
    Manchester
    Would £30 be enough to buy a decent multimeter? I have a £7 one at the moment but I don't think it would be accurate enough to measure those such voltages. On e the other hand I don't want to spend £100 on a tester when I will otherwise only use it to measure 12v output on a PSU where accuracy isn't that important.
    amazingtrade, Nov 27, 2010
    #21
  2. amazingtrade
    5,139
    Manchester
    Cannot find any multimeter which will read anything less than 200mv :(
    #22
  3. amazingtrade
    Tenson Moderator
    Nov 12, 2003
    5,947
    If your meter has a mV setting then it will do the job. Perfect decimal place accuracy isn't important here. As Rob says though, some crock clips are a good idea so you can attach before power on.
    Tenson, Nov 27, 2010
    #23
  4. amazingtrade
    RobHolt Moderator
    Oct 24, 2004
    I bought one from Maplin a couple of years ago and that has proven excellent.
    I'll see if they still sell it or something equivalent.
    RobHolt, Nov 27, 2010
    #24
  5. amazingtrade
    5,139
    Manchester
    #25
  6. amazingtrade
    Tenson Moderator
    Nov 12, 2003
    5,947
    200mV generally means the maximum for that setting. It will do less.
    The one you linked looks good. The one Rob mentioned has a capacitance measuring setting too which is unusual, but I don't know how much you would use it in IT.
    Actually, see PM.
    #26
  7. amazingtrade
    RobHolt Moderator
    Oct 24, 2004
    :D I was about to post a link to that.
    That would certainly do the job - its very similar to mine and is only missing a USB/PC interface so that you can use it with a PC.
    The max voltage ranges are higher than usual on the that model - good for testing valve amps should you ever have the need.
    Treat yourself - Christmas is coming.
    #27
  8. amazingtrade
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    They are Ebay item numbers, come on boys get with the program.
    sq225917, Nov 27, 2010
    #28
  9. amazingtrade
    RobHolt Moderator
    Oct 24, 2004
    Ah...... I thought perhaps they were datasheets :D
    RobHolt, Nov 28, 2010
    #29
  10. amazingtrade
    5,139
    Manchester
    Hiya Tension did you get the PM I sent you the other day? Thanks :).
    amazingtrade, Dec 6, 2010
    #30
