What is the difference between a dymano and an alternator
Discussion in 'General Chat' started by amazingtrade, Nov 17, 2004.
  1. amazingtrade
    5,139
    Manchester
    Just wondered what the differences are as I know dymano's used to produce the elecricity in cars before alternators. I thought an alaternator was just a heavey duty dymano.
  2. amazingtrade
    michaelab desafinado
    6,403
    Lisbon, Portugal
    It's dynamo btw ;) .
    I don't know if you've heard of it AT, but there's a really cool site on the net called Google. It lets you search for things ;) .
    I typed in "difference between dynamo and alternator" and the very first link I got was this one:
    http://www.rowand.net/Shop/Tech/AlternatorGeneratorTheory.htm
    ...which will explain it more fully than anyone is likely to respond here.
    michaelab, Nov 17, 2004
  3. amazingtrade
    Levi_501 Its in The Jeans...
    Nov 3, 2004
    453
    London
    In simple terms
    An alternator produces AC electric - then a rectifier takes off the low peaks of the current and gives you a semi stable current.
    A Dynamo produces DC electric - less efficient
    Levi_501, Nov 17, 2004
  4. amazingtrade
    joel Shaman of Signals
    Jun 21, 2003
    1,650
    A dynamo is what you are AT.
    An alternator is what Technobear is.
    Or maybe it's the other way round :p
    joel, Nov 17, 2004
  5. amazingtrade
    smudge
    May 24, 2004
    57
    "Magnets"
    Stuart
    smudge, Nov 17, 2004
  6. amazingtrade
    1,118
    by the cross
    dynamo D.C
    alternator A.C,
    themadhippy, Nov 17, 2004
  7. amazingtrade
    BlueMax
    Aug 17, 2003
    878
    South Coast of UK
    So AT is DC not AC ? :eek:
    BlueMax, Nov 17, 2004
  8. amazingtrade
    6,403
    Lisbon, Portugal
    Yes, alternators generate AC but most car alternators have the rectifier already built into them and so give out DC, which is what you need to charge the battery of the car.
    Alternators are far more efficient and can generate enough current to charge the battery even when the engine is running at idle wherease as dynamo (in a car) usually can't the battery at idle revs.
    It's all explained in great detail in the link I gave above.
  9. amazingtrade
    5,139
    Manchester
    Thanks so a car with a dynamo would have have to use the battery for a power source when ideling? So I assume if the car had its light on, winds wipers on etc the battery could go flat?
    amazingtrade, Nov 18, 2004
  10. amazingtrade
    Graham C
    680
    Leicestershire
    I don't think cars have had dynamos for 40 years. It's just what old gits call an alternator. Technically the difference is as stated above. Dynamo = DC motor being driven by something.
    Graham C, Nov 18, 2004
  11. amazingtrade
    6,403
    Lisbon, Portugal
    Yes, if you left it for long enough. But, as Graham C said, cars haven't had dynamos for donkey's years.
    michaelab, Nov 18, 2004
  12. amazingtrade
    5,139
    Manchester
    I am refering to the Mini, apparantly the early models used Dynamos instead of an alternator although this was quiickly changed by the mid 1960's. I know my dads Lada had an alternator and that was basicaly a rusian built Fiat 124 with a more modern dashboard.
  13. amazingtrade
    GAZZ
    Jun 21, 2003
    597
    northwest
    Hears one for you AT a Alternator will not charge a battery!!!
    GAZZ, Nov 18, 2004
  14. amazingtrade
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    you need a garage.
    rob, Nov 19, 2004
  15. amazingtrade
    GAZZ
    Jun 21, 2003
    597
    northwest
    Right then rob discharge your battery to say 1/2 charge then run around as usual for a couple of months then check it and see. An Alternator only keeps the battery as charged as what is in it!! Don't believe me then try it
    Gaz
    GAZZ, Nov 19, 2004
