Hi all, My first post... Having been bitten quite ferociously with the upgrade bug recently following a gap of a good few years, I am now in the pursuit of what is probably going to be the last cog in the current session. To clarify, things have evolved thus:- Out with an Arcam CD92 cdp, in with a Bel Canto CD1 Out with Monitor Audio GR20 speakers, in with B&W 803S’s Out with standard power leads, in with bespoke silver alloy leads + silver plated dist board, and solid silver interconnect by 'The Missing Link' Improvements overall are already pretty astounding, but I reckon the new kit wont work to it’s full potential without thinking about new amplification. Currently I am solid state so to speak, using Arcam FMJ A32 Int + P35 bi-amping the B&W’s. Having done lot’s of reading/searching/cogitating etc there is of course an immense amount of options to choose from. A few s/s power amps that seem interesting are below… Gamut D200 Mk3 Musical Fidelity KW550 (is this amount of power really necessary? -630 WPC) Ayre V5xe / K5xe Bel Canto e.One Pre3 / 2 x REF1000's ...and valve based Art Audio Jota or Argento David Berning ZH-270 (is there anyone in the UK with a s/h one?) or something more affordable, say by, ahem, the 'Affordable Valve Company' for example. In terms of ‘preamp’ I really only need a very simple volume control + one input, (passive?,). I can’t see that changing in the near future as I don’t anticipate adding any other source components to the Bel Canto. Surely there is a market for this sort of thing, but I don’t see much evidence having googled every permutation I can think of. Would love to hear if anyone has found anything along these lines. MF Audio’s preamp looks intriguing although it does have more inputs than I need. [URL]http://www.mfaudio.co.uk/passive_pre.htm[/URL] One thing that confuses me is published specs. More to the point watts per channel. I really don’t understand how certain solid state manufacturers swear only power upwards of 250 WPC will provide the desired results with relatively sensitive speakers - Musical Fidelity stand up please (my B&W’s are rated at 90dB/8 Ohm, 3 Ohm min), whereas valve based units are commonly as low as 15 WPC yet can sound wonderful. Someone, please help! Surely a watt is a watt is a watt. Budget wise it’ll be about £5K GBP, for both power and if necessary pre, or even integrated. Music wise, one day it’s Beethovens 9th, the next Bob Marley, the next some downtempo electronica, after that maybe Metallica. Everything to be honest. Room size is smallish - 3.8 x 4.8m x 2.9m and i'm not looking to blow the roof off volume wise. Thanks for taking the time to read this. Would be very grateful to have some advice on the above.
