Why do you visit audio forums?
Discussion in 'Hi-Fi and General Audio' started by RobHolt, Sep 19, 2010.
  1. RobHolt
    flatpopely Trade - AudioFlat
    Jun 20, 2010
    273
    York
    I love the dichotomy of the 'new hi fi selling model' using forums and using the same to stop people buying product. Ace plan.
    flatpopely, Sep 23, 2010
  2. RobHolt
    Richard Dunn
    Jul 5, 2006
    1,198
    I am not a hi-fi selling model for anyone but myself. I just promote a direct to market approach as opposed to going through slurping retailers who double the price of your product. Just think how many more customers you would get at £625 instead of £1250 and you would make the same profit, you are just feeding the slurp, and in the process the customer is overcharged.
    I am in a quite unique position, probably only Les is similar but larger. My customers become my friends because I don't have masses of them because I am a one man company, so if there is someone I wouldn't want as a friend then I don't want them as a customer. Anyway I don't like you but I wouldn't throw you out of my room, nor would I throw out Mescalino or Basil or others I have enjoyable barnies with, SQ is a special case he is just a nasty bit of work - full stop, and I am far from the only one who thinks so.
    Richard Dunn, Sep 24, 2010
  3. RobHolt
    Nibbles
    Sep 11, 2010
    9
    and more blind testing
    Think it's VERY TELLING that it's usually the marketeers who bottom line are opposed to blind testing..:MILD:
    This wouldn't be their realisation that they know full well what they're marketing won't stand the acid test, of course...;)
    Get it in the home then and blind test it... lol
    Nibbles, Sep 24, 2010
  4. RobHolt
    Richard Dunn
    Jul 5, 2006
    1,198
    I have been doing the "acid tests" for over 30 years, you are a bit late into this argument, I now reject them for what they are, a delusional fantasy, *from experience*.
  5. RobHolt
    jcbrum Black Bottom fan
    Mar 22, 2008
    222
    Brum
    This is no way to contemplate a purchase. In fact it's a recipe for failure.
    I think what you are saying is that they were all fatally flawed, but you were simply picking the best possible from a poor bunch.
    The sensible way to make a purchase is to set a standard and to draw up a specification for that standard.
    With HiFi, imo, that is relatively easy to do, and can be achieved from a technical spec, or correct re-production of the original sound, or as a last resort, a correct re-production of a selected known recording.
    In other words match the performance to the required specification.
    To do anything else is not HiFi, but I suppose it might be 'Home Entertainment'.
    To do it simply on preferences between a few items that are offered is a bit like choosing a new car by saying " can I have a red one please ", " I really like red ones, and so do all my friends on the red car forum. "
    JC
    jcbrum, Sep 24, 2010
  6. RobHolt
    Dave Simpson Plywood King
    Sep 30, 2005
    395
    Third stone from the Sun
    Thanks Simon. At the moment it's in favor of wall outlet>CDS, preamp's HC, power amp, preamp's NAPSC at end of chain. vs trying all the combinations by ear. Not sure how I'd test for the difference between signal and ground potential without the skill and tools.
    What amazes me is the difference in sound by fixing one wobbly speaker spike only out by a few mm, torquing the hell out of the outlet screws (lowering resistance?) and then changing order of the plugs. The differences aren't huge in sound quantity but quality. I've completely lost any trace of glare heard occasionally on peaks and with the upper mids of pianos (stuff I originally blamed on flutter echo and a "hard" sounding room.) As well, complex passages are easier to follow now with less sense of distortion on all recordings. No change in bass, treble or PR&T but I do hear less image wander and a more solid central image also. All in all, it sounds like I've bought new gear.
    Dave Simpson, Sep 24, 2010
  7. RobHolt
    Mescalito
    Apr 21, 2009
    226
    Scottish Highlands
    Beautifully put, Rob.
    Basically, buy what the hell you like, but at least let it be an informed choice. Music & hi-fi are two entirely different beasts.
    Music works at a visceral level. The Job of the hi-fi is to render it as close to the composer/performers intentions.
    Chris
    Mescalito, Sep 24, 2010
  8. RobHolt
    Mar 22, 2008
    222
    Brum
    Taken literally, this statement is quite clearly a mistake.
    This statement is not a mistake, even though it appears to contradict the first one.
    Referring to the thread topic, one of the reasons to participate in an audio forum is to help and inform other members who may be confused and ill-informed about HiFi reproduction.
    High-Fidelity by definition means the ability to replay a sound recording with the greatest possible accuracy, so as to re-produce the sound of the original event.
    This depends on taking the chosen recording as the yardstick.
    The best way of evaluating any component in the re-play chain is by comparing the output to the input. Any changes made to the signal, with the exception of gain, represent a distortion of one sort or another.
    The best way to do this is by objective scientific analysis under controlled conditions
    Reactive and resistive components alter audio signals, but they will never improve the quality of the input signal. The best products degrade the input signal less than others.
    In the audio replay chain, the errors and distortions from technically weak components is multiplicative more often than not. It is not appropriate to attempt to 'improve' the sound by using some distortions in an attempt to cover up others.
    'Golden ears' and 'personal preferences' are particularly poor ways to achieve the objective since the senses are so easily fooled, particularly with visual input as an aid to sonic evaluation.
    For example, - I think that believing that the order of the mains plugs in a multi way mains socket has any effect on the sound is a case in point. IMO it's utter rubbish. I do accept that some are sincere in their belief, but nevertheless they are deluded.
    That is what is wrong with evaluation by 'preference'. Most ordinary people are simply in no position to make any sensible assessment, and this needs to be explained to them so that they may become better informed and less deluded.
    JC.
  9. RobHolt
    Joe
    Mar 15, 2005
    896
    So how would you go about explaining to someone who hates Marmite that their 'preference' is misguided?
    Joe, Sep 24, 2010
  10. RobHolt
    Mar 22, 2008
    222
    Brum
    I like Marmite Joe, but your question is not apposite. :)
    It's like your 'someone' saying their HiFi is no good when playing Mozart but wonderful when playing Gershwin.
    It's proper to express a preference for artistes or composers, but satisfactory replay equipment will re-produce either equally as well.
    Regardless of their preference.
    JC
  11. RobHolt
    chefren
    Jul 30, 2007
    17
    Finland
    Such equipment does not exist. Hence this hobby has evolved around music reproduction.
    chefren, Sep 24, 2010
  12. RobHolt
    Mar 22, 2008
    222
    Brum
    It most certainly does. You have obviously been misinformed, and are possibly deluded :)
    JC
  13. RobHolt
    Purite Audio Purite Audio
    Nov 25, 2006
    1,250
    It certainly does and I am listening to it at this moment!
    Keith.
    Purite Audio, Sep 24, 2010
  14. RobHolt
    chefren
    Jul 30, 2007
    17
    Finland
    Please inform me about this wonder system that will reproduce every musical work equally well (doing it equally badly will not cut it btw).
    Everything from organ works to dance music to ambient noise to a capella vocal music to rock and full size orchestras and everything in between, all at sufficient volume levels and near-natural dynamics.
  15. RobHolt
    Mar 22, 2008
    222
    Brum
    HiFi has no understanding of music. All it does is deal with electronic signals. Irrespective of whoever created them.
    JC
  16. RobHolt
    Mar 22, 2008
    222
    Brum
    It's your brain (not your ears), and your prejudices, that does the rest. :)
  17. RobHolt
    chefren
    Jul 30, 2007
    17
    Finland
    So if I listen to organ music and my system fails to reproduce a 20Hz tone at natural levels its all in my brain and I'm deluded? Gotcha.
  18. RobHolt
    sq225917 Exposer of Foo
    Jan 11, 2007
    1,514
    Come on JC, just because you've never messed around with grounding arrangements in your amps or spent happy afternoons hunting down the last sq root of a fart to a nV in a phonostage shouldn't mean you don't believe in the 'order of plugs in a multiway strip' fairy... ;-)
    The thing is it's such an 'almost' plausible explanation. It has just enough believability in it.
    1. Has the foo-susceptible person heard of grounding- check.
    2. Is he aware of how grounding paths can in some instances change the sound- check.
    3. Can he measure them himself- no of course not- check.
    4. Does the claim centre around tiny audible changes that only someone who believes they have magic golden ears can hear- check.
    Bingo we have a winner. The truth is obvious, it makes no F-in difference to how your hifi sounds because every plug is at exactly the same ground potential.
    But I did just like the idea of sending Dave off on a wild goose chase for a few hours, and you know what, he's probably found audio nirvana because he thought he was making a difference.
    What's not to love, he get's to fulfil his lunatic tendencies and i get to bend his actions to my will, murrgh ha ha...
    sq225917, Sep 24, 2010
  19. RobHolt
    Mar 22, 2008
    222
    Brum
    Chefren, ..... You obviously haven't heard a good system yet, ;) .... and yes, you are showing symptoms of audiophile delusion. :)
    JC.
  20. RobHolt
    Mar 22, 2008
    222
    Brum
    I bet you love kicking the shit out of cripples too.
