I came home from school this afternoon to find my sister worried that the hifi and/or the PC was broken. She'd turned all of my separates off, but when I turned it all back on my amp was set to the auxillary 2 input, which isn't connected to anything whatsoever. She insisted that she could hear music using this though, just very very very quietly and it necessitated turning the amplifier up to maximum. I had a mess with the DAC, and that was set to SPDIF output, receiving a toslink signal from the computer, yet the DAC is connected to the CD input. I was just in total disbelief at this point, surely theres no way you'd hear music from it like this - the amp set up to receive a signal from an input that nothing is plugged into. But no, if I start playing a file through the computer and the DAC, and I can hear it really quite clearly through the speakers if I turn the volume up loud enough., I'm presuming this must be down to either rubbish internal shielding around the different inputs, or poor amplifier design where the input selection isn't very clean at all. Certainly made me appreciate how noise could get into the amplifier from external sources or 'leak' through other connections, which must somehow impact the sound. I found the same problem with both aux 1 and 2 inputs. The inputs connected to other bits of kit (tuner) didn't exhibit the same thing. Is this sort of problem/issue typical of relatively low end kit (the amplifier in question is a Marantz PM7000, cost £300 almost 2 years ago). Is there anything I can do to improve the shielding inside the amplifier fairly easily (I was thinking of a DIY addition of copper shielding - seems fairly straight forward but is it likely to help, and I am worried about heat since the amp runs warm enough anyway?). Cheers, apology for the long post, just thought I'd best explain what was happening properly :)
