Win XP will be the death of me!
Discussion in 'General Chat' started by lhatkins, Jun 10, 2005.
  1. lhatkins
    lhatkins Dazed and Confused
    864
    Honiton, UK
    Windows is very good for those people who don't want to know how a pc or software works. Windows does everything for you so you don't have to think about it.
    I'm as gulty as the next person here, I've been bought up with Windows and it kind of stuck, quite hard to change over to Linux, learning all the new terms etc, its quite funny really I was having this conversation in the pub on Saturday night. It got really interesting, he start of with "I don't know why people bother with linux", 3 pints and an hours later I think I got my point across, hehe :)
    #21
  2. lhatkins
    5,139
    Manchester
    Yeah I totaly understand the point on linux, and I said I use it myself, its just for a main home operating system Windows is just so much easier to live with.
    amazingtrade, Jun 10, 2005
    #22
  3. lhatkins
    864
    Honiton, UK
    No problem, Microdirect have it for £43.90+ vat. nicely.
    #23
  4. lhatkins
    864
    Honiton, UK
    Yep agree, its eaiser to live with, because its been the main stream OS for so long and everyone is used to it.
    Linux has come a long way in just a couple of years, I remember installing Mandrake 9.1 and it was a real handfull to get anything working, now its a completely different story. I remember plugging in my usb pen into my Fedora machine and thinking, I'll need to install some drivers or mount it know, when just then a window poped up with the files on, I couldn't beleive it!
    #24
  5. lhatkins
    864
    Honiton, UK
    Ok, I'm bringing this one up again, as my new psu has arrived.
    Installation wasn't too much of a problem but the back panel of my case wouldn't fit the switch in, so I had to remove the plastic cover of the back of my case, not a real problem, but they could have positioned the switch on the psu better.
    But still getting Bsods and corrupt registries, this hasn't solved my problem, I've not reinstalled windows yet, I might add, but I was hoping for an instant fix.
    Any more ideas on how to fix XP?
    lhatkins, Jun 30, 2005
    #25
  6. lhatkins
    Tenson Moderator
    Nov 12, 2003
    5,947
    I guess its a VIA chipset? They are known for having bad USB support, even under Linux and basically riddled with problems. If you can get a proper AMD chipset (do they make them still?) you will be much better off.
    That or send it back and go Intel. The CPU's may not be too different now but the mobo chipset's Intel make are miles more stable in my experience.
    How the hell did you get your 1Ghz P3 to run at 60c? I have had 2 and never seen them top 43c!
    And yeah.. you know I hate XP even more than AMD's!
    Tenson, Jun 30, 2005
    #26
  7. lhatkins
    michaelab desafinado
    6,403
    Lisbon, Portugal
    To be fair the thread title is a little misleading as the problems you seem to be experiencing appear to have not a lot to do with Windows XP and everything to do with some hardware issues on your self built PC. I imagine that you'd probably have similar issues with any other OS.
    michaelab, Jun 30, 2005
    #27
  8. lhatkins
    I-S Good Evening.... Infidel
    Jun 25, 2003
    4,842
    In a world of pain
    lhatkins - that's very frustrating. I feel bad about that having suggested the PSU as a potential culprit.
    Download a program called Speedfan and load it up on your machine. Run it and go to the S.M.A.R.T tab. Select your hard disk from the drop down tab. At the bottom there are two bars, Fitness and Performance. See what they say, and if there are any warning points in the list of SMART data.
    I-S, Jun 30, 2005
    #28
  9. lhatkins
    MattC
    Dec 9, 2003
    51
    The South-West
    wireless under linux
    Lee,
    I recently setup a DLink DWL-122 wireless usb adapter under linux for a colleague, with no problem at all, using the helpful instructions here
    Matt
    MattC, Jun 30, 2005
    #29
  10. lhatkins
    864
    Honiton, UK
    I think the 1ghz chip was getting old, it was about 50c to start with but I guess after 3 years they start to break down? don't know probably the heat sink was full of fluff as well which doesn't help.
    Well I have 4 friends who have the same baord and setup as me but don't have a problem, I thought it was memory, but after running a memory burn in test it past fine, I can't figure out what the heck is going on.
    Yes its a via chipset, I was worried about this but Asus only do Via or Nvidia but the nvidia boards are expensive, I do admit to being a bit of a cheapskate.
    Yes I read somewhere that XP ships with a dodgy usb device driver, so I've disabled the usb in the bios to stop XP seeing them, to see if that would help.
    Nothing is working, I just don't get it, I've tried 2 diffenent XP disc too to make sure it wasn't a duff disk.
    What more can I do, I could return it, all the bits came from the same place, but what can I tell them, XP will not install on it? Looks like I'm out of pocket whatever I do, nobodies fault, but I'm totally fed up with it.
    I've always built my own systems, I've built loads for other people, but never come across any of these problems before, I built Dom's machine, he's not had a problem with it.
    I don't know what I'm doing wrong, or how to find out what is causing these problems.
    I'll have a look for that hard drive program, I mean that would be the only original peice left, it is a IDE not SATA if that makes any difference, and its only 12 months old.
    Thing is I ran a Linux Live cd, and it ran perfectly, I might try to install Linux and see if that gives me any problems, I'm convinced the problem lies with XP.
    One other thing about the psu I'm a little disappointed with, its made my case temps rise by 4 or 5 deg c, which has put up my cpu temps, it does run really hot too.
    #30
  11. lhatkins
    864
    Honiton, UK
    Nice one Isaac, got and installed the prog, the fittnes bar is at 50% now that's not good news is it? Don't tell me I have to buy a new hard disk, no no no no.
    Don't feel bad about the psu, I was told by other people as well the same thing, so I though with so many people saying the same thing it was a worthwhile guess, and I also wanted a quieter psu too, so it'll work out in the end.
    #31
  12. lhatkins
    864
    Honiton, UK
    Suse 9.3 Picks the wireless up straight away no problem, but you have to buy this (I "borrowed" mine from work!) but I can't get Suse 9.2, FC3 or Mandrake 10.1 to see a wireless network no matter what I try, I take it you use a Realtek chipset? RT2500.
    #32
  13. lhatkins
    Jun 25, 2003
    4,842
    In a world of pain
    I have this with my new HDD. The fitness bar is 40-50% and the machine occasionally randomly resets itself followed by the hard disk spinning up again. My previous disk (which is still in the machine) shows 100% fitness and performance. I suspect it might be the cause of the issues I have. If your BSODs are things along the lines of IRQL_NOT_EQUAL_TO or similar then it might be a hard disk (or memory, but you already excluded that) issue.
    I-S, Jun 30, 2005
    #33
  14. lhatkins
    Tenson Moderator
    Nov 12, 2003
    5,947
    The fact the live *CD* works but putting XP on the hard disk doesn't, does point towards the hard disk doesn't it.
    #34
  15. lhatkins
    864
    Honiton, UK
    And the hard disk showing 50% health as well, I take it there is no way to revive the hard drive like a low level format or something, .
    This is not turning out to be a cheap upgrade, I really wish I'd not bothered.
    #35
  16. lhatkins
    Tenson Moderator
    Nov 12, 2003
    5,947
    Hard disks come with good warrantys so it shouldn't cost you ore than the postage. I know Western Digital drives have to go back to Germany but they are fast at getting them back and don't quibble.
    Tenson, Jul 1, 2005
    #36
  17. lhatkins
    864
    Honiton, UK
    I ran the seatools diag software last night, did a full scan, and it came back as passed, might email them and see if they can suggest a course of action, can't prove a fault though.
    lhatkins, Jul 1, 2005
    #37
  18. lhatkins
    Tenson Moderator
    Nov 12, 2003
    5,947
    Then break it lol! Run a power supply across random parts of the circuit board. But don't put it back in your machine to test if it is broken ;)
    Tenson, Jul 1, 2005
    #38
  19. lhatkins
    864
    Honiton, UK
    You know I've been building pc for years, it never used to be so hit and miss, if something went wrong it used to be really easy to find the fault, now it just seems like guess work, I really appricate all the help/advice everyone is giving, but I would be a lot happier if I coudl 100% put it down to a faultly piece of hardware. A mate of mine did point out to me that my motherboard's bios might not 100% support my cpu, cos of the new "venice" core the 64's use, so keep the bios updated as soon as new ones come out, as the updates alway sasy "code for new cpu support" etc. Maybe my problem here is I'm mating a old (ish, if you call 3 months old) m/board to a new CPU and they're just not compatible, or the new venice core isn't stable, hum, maybe I should have gone for the older core, ya lives and learns! :)
    lhatkins, Jul 3, 2005
    #39
  20. lhatkins
    Tenson Moderator
    Nov 12, 2003
    5,947
    Surely if it was that, the live CD wouldn't work. Try installin Linux onto the hard disk.
    Tenson, Jul 3, 2005
    #40
