Windows Vista Tuning Tips for audio processing
Discussion in 'Hi-Fi and General Audio' started by jonesi, Feb 16, 2011.
  1. jonesi
    jonesi
    Jan 5, 2008
    35
    Stevenage
    I found this page while researching NI's Traktor software:
    http://www.native-instruments.com/k...indows+Vista+Tuning+Tips+for+audio+processing
    Some of the tools mentioned in the article may prove useful.
    I've thought for a while that my HiFace sounds better when connected to my PC than when connected to my laptop. The DPC Latency Checker shows that the PC has much lower latency. Running LatencyMon on the laptop showed me that it is the ACPI battery device that is the spanner in the works.
  2. jonesi
    Snoo
    Sep 8, 2003
    240
    Bristol
    Hmm. I don't see how latency would affect your sound quality. Latency is an issue when you are recording because it's a delay between say the guitar you are recording and the sound you hear. So you try to reduce it as much as possible. All different pc's and sound cards will have different values.
    Snoo, Feb 16, 2011
