Firstly I'm looking at the lovely early original xerxes I bought and apparently theres transit screws somewhere. Without a manual, and no chance of any downloads I can't find them anywhere. :rolleyes: Any clues which ones to undo guys? Theres three under the platter, two shiny slotted ones and a well worn philips one, or should I be looking elsewhere?. The next problem is the famous sag on the armboard, its at about 0.5mm at the front and just under 2mm at the back. Roksan propose that the 2mm at the back is a stabilised sag that won't get any worse, they reckon the solution lies in tilting the main bearing in relation to the sag. I'm sceptical. A lot of the roksan buffs (apart from Roksan!) recommend a tweek by fitting a mending plate between the main board and the sagging section to push it back up to level. The thing is, do I do this before I fit my heavy SME 309 arm, or do I tough it out level the platter and suffer a slight dodgy azimuth on my tonearm, confident roksans isolation vision hasn't been sullied. Does the mending plate tweek make any difference sonically? Is it worth doing? I'm really pleased with the tables condition otherwise. One more thing, is there any internal earth wire that needs connecting I can't see one. Opinions greatly appreciated! Thanks in advance!
