For Sale: 4 X AudioPrism Quietline plug-in shunt filters
Hampshire
Parallel shunt filter, removes noise with no current limiting. Cumulative effect if used in groups on a circuit. This New & Improved Version 3, has more noise reduction and an LED power indicator!
Your equipment is constantly bathed in a "sea" of electrical noise. Most line filters treat only the power coming directly into the equipment. They do nothing about the noise generated by other electronic devices. The Quietline Noise Reduction System is a new way to reduce the electrical noise and interference that degrades the sound of your audio system.
The Quietline Noise Reduction System is more effective than conventional filters, because it reduces noise at its source. Quietline is a very effective shunt filter. It sits across the power line, rather than in series with it, cleaning up noise and interference without affecting the flow of power to your electronics.
There are several sources of electrical noise in nearly every building. The power line itself is inherently noisy and can act as an excellent antenna for atmospheric electrical noise. Defective utility equipment and loose or corroded connections can also create noise.
Radio-frequency interference or RFI (usually radio or TV signals), can have grossly audible effects (such as a buzz from a TV station or hearing CB calls), or more subtle effects (such as veiling, grain and flattening of perspective.)
Electromagnetic interference (EMI) is the "hash" radiated by your computer as well as the pops from your refrigerator's compressor. This noise can enter your electronics through the power line, speaker cables or even along the shield on interconnects.
It isn't enough to reduce EMI and RFI where they enter. You must suppress the noise at the source. The Quietline Noise Reduction System is a set of noise-suppressing modules that treat line noise and interference throughout your home to reduce the noise from computers, digital clocks, power tools and other offending appliances. The Parallel shunt filter, removes noise with no current limiting. Cumulative effect if used in groups on a circuit. This New & Improved Version 3, has more noise reduction and an LED power indicator!
It isn't enough to reduce EMI and RFI where they enter. You must suppress the noise at the source. The Quietline Noise Reduction System is a set of noise-suppressing modules that treat line noise and interference throughout your home to reduce the noise from computers, digital clocks, power tools and other offending appliances. Noise Reduction System is a whole-house treatment for noise.
Reduced electrical interference is audible as cleaner sound, improved detail, a wider, deeper soundstage, reduced graininess and less listener fatigue. Even if you already use another power line filter, you will hear an improvement when you install the Quietline Noise Reduction System.
The Quietline plug-in filter has inspired other manufacturers products such as Russ Andrews Silencer, IsoTek, Kemp etc.
More info here:-
http://www.audioprism.com/quietline.html
I have two sets of 4 for sale at £60 each set including p&p (£119.95 new)
They are in mint condition in original box
Contact Steve on 01252 695525 / 07725 874832
