bottleneck
talks a load of rubbish
bass bins wont be built until I have a room capable of taking them.
they really are a force unto themselves.
bottleneck said:oedipus, I'd like to build some horn loaded bass bins .. so that wont be a problem.. but is the room good ?
..this is an example...
I just want the basics as right as possible..
Richard Dunn said:With your speakers get the biggest room you can - full stop....Richard
andyoz said:One thing that strikes me Bottleneck looking at your current set-up is you're almost doing 'nearfield' listening with the speakers so close to the couch - direct to reflected energy ratio will be high.
If you were to purchase property in Picture 1 (for example), it indevitably looks like the speakers will be MUCH further away from the listening position than you have been used to. Have you ever listened to gear in those conditions and did you like it?
bottleneck said:your speakers may go to 30hz, but if your room isn't 24 feet long, you're never going to hear it!!
