Was the previous room all concrete walls?Do you know what is behind the plasterboard?,(if anything)The only thing I can think of,is the plasterboard is absorbing the bass.The smaller the room the more absorbtion you should need,but I'm thinking your walls are sucking out the bass,instead of putting back into the room.
Maybe worth getting the freq response of your speakers,where the bass does roll of,then run the CARA freq sweep test they do and see/hear where you bass is cutting of.I used RPG products to help my roo, but I had boomy bass,not bass suckout.But I suspect the plasterboard walls.
