Binary Watch
MO!
MOnkey`ead!
From I Want One Of Those...
If you've ever had a problem telling the time, then worry no more. The Binary Watch is so completely impossible to use (unless you're a code-head) that not being able to tell the time is no longer a cause for worry, but just perfectly normal behaviour. Of course for those of you who 'get it', the Binary Watch - whilst palpably a watch - is not about telling the time, it's about being carefree and eminently cool. It either says 'I'm sufficiently techno-cool that I can actually tell the time on this thing' or 'I'm so laid back I don't need to know what the time is, but cool lights, huh?'.
As the classic joke goes, 'there are only 10 types of people in the world - those who understand binary, and those who don't' and it doesn't matter if you're a 1 or a 0, it's a unique if slightly daft gizmo whichever way you look at it. Though of course if you look at it upside down, the time will be different. Nevertheless, this is one cool watch. Here's how it works...
There are two rows of LED lights on the watch face, the top row shows 4 lights with corresponding numbers, and is the equivalent of the hour 'hand', and the second row shows 6 lights and corresponding numbers, and is the little 'hand'. Apparently the translation of time from binary to decimal is easy: simply (huh) add the numbers next to the LEDs on the upper row to tell hours, and add on the lower row to tell minutes. The time is displayed for five seconds when the side button is pushed - but if you think that's long enough to work it out then you're considerably cleverer than we are.
It comes with a leather strap, is made from solid stainless steel, and is water resistant to 90 feet - just in case you wanted to show off your binary proficiency to a halibut
